Results 1 to 9 of 9
Thread: Phosphate levels?
    Phosphate levels?
    I have never heard of this before. My son in law was having a persistant problem that was solved when the pool store diagnosed his problem as something with phosphates. They sold him a product that solved his problem.
    Sorry he was very sketchy on the details. all he knows is that "phosphate was the problem and now it's fixed"
    Is this something I should be checking regularly?
    How does it fit in with the BBB method?
    thanks.
    6600 gal IG concrete/gemcoat
    Fresh water
    1 HP motor
    StayRite PLM 100 system 2 filter
    full sun
    Treasure coast, Florida
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Phosphate levels?
    Phosphate levels do not matter in a properly chlorinated pool. Most likely his problem was low chlorine (for his cya level). But at least his wallet is lighter now
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Phosphates aren't a problem. Ignore them.
    They provide food for algae, but if you don't let algae get started it doesn't matter. It's kind of like saying you are fat because McDonald's sells shakes. Sure, too many shakes can make you fat, but if you don't go to McDonald's it doesn't matter what food they sell.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Read chemgeek's answer here: posphate-t65360.html
    OK, so if I understand correctly.
    Phosphates feed algae.
    By preventing algae with proper cholirination it doesn't matter what the phosphate level is.
    Reducing the phosphate level is therefore unnecessary.
    Maintaining proper chlorination to prevent algae blooms is all that is required.
    Fresh water
    1 HP motor
    full sun
    30,402
    You got it dead perfect.
    Donldson's Avatar
    NW Ohio
    2,880
    Quote Originally Posted by avidone1
    Can we get that on a sticker and start secretly sticking them all over pool stores, such as next to the PhosFree?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Quote Originally Posted by Donldson
    Too funny! Do it but don't get caught !
    Thanks....TFP is the best pool resource on the web.
    Fresh water
    1 HP motor
    full sun
