Results 1 to 8 of 8
Thread: Filter/pump replacement question
    munky's Avatar
    Jul 2013
    Naylor, Arkansas
    12
    So, currently I'm still using the dinky little 1000gph cartridge filter/pump that fame with my pool. I was thinking about upgrading to Intex's 2650gph sand filter/pump, but I have a question about that.
    We're planning on upgrading to a "real" AGP next year, probably around 15' x 52" round. That being the case, it doesn't seem worthwhile--or cost efficient--to upgrade now, when we'll just have to get a new pump/filter next year for the new pool.
    So, is there anything I can do to improve the effectiveness of the current filter/pump for this season?
    munkyPool
    AGP: Intex Ultra Frame 14' x 48", 4600 gallons
    Catrtidge pump/filter (included w/pool)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Filter/pump replacement question
    The 2650 gph filter would work for a "real" 15X52 as well, though it will require the box adapter discussed in the intex plumbing topics. Thinking outload, a 15' pool is still quite small...not much of an upgrade from what you currently have...so it is likely when it comes down to it, you may go larger? That might be a reason to wait, if you can survive with your current filter.
    munky's Avatar
    Jul 2013
    Naylor, Arkansas
    12
    I've heard you can get a different filter cartridge that works better than the cheap ones you get at Walmart. Do they actually work better? And is it worth it to get them for one season?
    munkyPool
    38,308
    I have seen a few reports of the Unicel cartridges working quite a bit better than the Intex. And they are reusable. You should be able to find the model number with a quick search.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Unicel C-4607, or filbur FC-3710 for type "A"
    Unicel C-5315, or Filbur FC-3752 for type "B"
    38,308
    Thanks, Charlie
    munky's Avatar
    Jul 2013
    Naylor, Arkansas
    12
    Awesome. Thank you!
    munkyPool
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Caveat about ordering from Amazon or other online places. READ the description, closely. Quite a few sellers are advertising "replaces" or "same as" these quality filters. If in doubt, ask the seller.
    Instructions for cleaning in Pool School, and Unicel has instructions packaged with each filter.
    I'm still using the first one I bought last season. There are others here that have run them for 3 and 4 seasons, as long as they are cleaned properly.
    Very worth the extra money spent on these!
