Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Target FC
    HamburgerChef's Avatar
    Apr 2013
    Indianapolis Indiana
    100
    Target FC
    Here are my latest test results. Recovering from the flu so pool has been neglected for the past few days.
    PH 8.2
    FC 0.5
    TA 250
    CYA 25
    According to the CYA chart I should have a target FC level of about 3.5. Does this mean I should put 3.5 into the Pool Calculator or does this mean I should have an average FC of 3.5. In other words should I put say FC 4 into the calculator if I average a FC loss of 1 per day so that I average FC 3.5?
    13,500gal AGP Matrix 24'
    Pentair Sanddollar SD-80 75GPM filter, Pentair Dynamo 1HP 2 speed pump
    Polaris 65 pool cleaner
    (20'x30" solar heater to be installed)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Target FC
    I would raise the CYA to at least 30. At 30 you need to maintain an FC level of 2-6 and don't let it go below 2.
    Check out chlorine / cya chart in pool school. . If you have alot of sun on the pool you can raise it some more to help with FC loss.
    Jeff
    30,419
    Re: Target FC
    Your pH is too high - lower it into the mid 7's
    Keep your chlorine between the numbers suggested....don't let it get lower than that which it is now.
    Apr 2013
    100
    Re: Target FC
    Quote Originally Posted by pwrstrk
    Sent from my iPhone using Tapatalk.
    Still in the process of raising CYA to 30. A whole bottle of HTH Stabilizer Conditioner got me to 25.
    So am I correct in thinking that the target # in the pool calculator from pool school is the FC level to have average through out the day then? It is not the level to bring FC up to everyday after testing?
    Apr 2013
    100
    Re: Target FC
    Do you mean between the target and minimum FC levels in the pool calculator
    I added 3lb of dry acid today. Going to the store to buy miuratic acid soon.
    30,419
    Re: Target FC
    Do you mean between the target and minimum FC levels in the pool calculator?
    Yes
    Apr 2013
    100
    Re: Target FC
    Thanks
    (my daughter wanted more smileys)
    Apr 2013
    100
    Re: Target FC
    I am going to the store to buy 20 baume muiratic acid. How much do you think it will take to bring my TA down to 80? it comes in 1 gallon jugs.
    Re: Target FC
    The Pool Calculator is your friend.
    Apr 2013
    100
    Re: Target FC
    At the bottom it says there is an extra calculator. Easy to miss it since its not colored. It says add 4.5 gallons of 20 baume. Although it says that its not accurate if your TA is outside of 80-120. I will buy 6 gallons to start and see where that gets me.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Target FC
    Quote Originally Posted by HamburgerChef
    Just don't add it all at once.
    Apr 2013
    100
    Re: Target FC
    Quote Originally Posted by Richard320
    Sorry, have too Pool calc says.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Target FC
    My sarcasm detector is malfunctioning....you are joking, right?
    Apr 2013
    100
    Re: Target FC
    Lol
    Apr 2013
    100
    Re: Target FC
    Just put in the first gallon of Acid. It got my PH to 7.1. Then added 9 ounces of Cyanuric. Should put me at 30. Have the return frothing up the water pretty good.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Target FC
    Good job Burger !!!
    Jeff
    Jun 2012
    Howell, NJ
    977
    Re: Target FC
    Hmm, why do I suddenly want a hamburger?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Apr 2013
    100
    Re: Target FC
    I just rechecked FC. Here is the rundown for today.
    9:30 am
    PH 8.2
    FC 0.5
    TA 250
    CYA 25
    10:30 am Added 3lb dry acid and 6 cups 10% bleach. This should have brought FC to 3.5. Didn't test to make sure though.
    6:00 pm
    PH 7.8
    Added 1 gallon Muriatic Acid 20 baume and 9oz Cyanuric acid. Pointed return up to raise PH.
    8:00
    PH 7.1
    FC 1.5
    Added 6 more cups Bleach.
    This means my pool used 2ppm of chlorine between 10:30 am and 8:00pm. Twice the 1ppm it normally uses. Is this a sign of algae growth? There was about 50% sun and clouds today. The pool has been neglected all week until today due to a bout with flu. By neglected I mean added 2 cups bleach each day without testing.
    30,419
    Re: Target FC
    That amount is probably not nearly enough to cover your daily FC loss unless the pool is covered.....Is it?
    Most pools lose 2-3 ppm daily.....that's about 2 quarts in your pool.
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Target FC
    What is your CC ? How does your water look ?
    You added stabilizer to get to 30 correct ?
    How about adding enough chlorine to get to 6ppm and do a OCLT test to see how much you lose. Check FC in the morning before sun gets on the pool. See what ya got then.
    Jeff
