Results 1 to 8 of 8
Thread: 3 week old pump quit working
    Jul 2013
    central North Carolina
    27
    3 week old Hayward super pump quit. Checked breaker and switch everythings fine but pump just want run make noise or anything any suggestions?
    16000gl ig fiberglass 1.5 hp vari sand one skimmer
    Jun 2013
    SpringHill FL
    415
    Re: 3 week old pump quit working
    Is your timer turned off?
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jul 2013
    27
    no timer
    Jun 2013
    SpringHill FL
    415
    Did you install or have it installed?
    Nathan
    Jul 2013
    27
    I installed the pool but had electrician wire everything
    Jun 2013
    SpringHill FL
    415
    Do you have a volt tester? They are cheap u can get one at any hardware store its 2 leads with a couple lights to test 115volt 230volt if everything is turned on check the terminals on the pump. 2 screws on the cover plate then remove it and you will see the terminals
    Nathan
    Jul 2013
    27
    Called electrician he is on the way!!!
    Feb 2013
    Yukon, Oklahoma
    220
    Interested to hear what the problem was.......I am getting paranoid of chinnese bearings in stuff going out. I would be willing to bet that Hayward may be sourcing inexpensive bearings from China to keep costs down.
    Bob E.
