Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 112
Thread: BigJD's Pool Build by the numbers
    Folks,
    We are embarking on our pool build and I want to take you guys on the journey with me!
    Some starting notes:
    1.) I have a pretty challenging site: big slope, lots of trees to remove, and most definitely granite ledge
    2.) I have selected a PB. They have done 8 or so pools in my development, all with positive results and the PB project manager lives in my development as well.
    3.) We are going with a vinyl liner. Mostly due to cost, but partly due to comfort (my wife grew up with vinyl and prefers it).
    4.) We will not have a spa.
    5.) My wife intends to do laps in this pool. Should the shallow section be deeper than the standard (which I assume is 3'6" correct me if I am wrong)
    We have made some decisions about the pool already:
    • Pool: 21'X40' Mountain Oasis (I believe it is made by Imperial Pools with a Premier liner). The pool will be approximately 21,000 gallons, have an Autofill and overflow
      Cleaner: Port for a Polaris 280, might buy now or later
      Pump: This is open but I am leaning toward the Hayward Tristar
      Filter: PB recommends Sta-rite modular media ... I am open to suggestion (I don't want DE)
      Heater: Heat Pump, Leaning toward Hayward
      Controls: Aqua Plus 2, with 40K SWG
      Light: Open to recommendations, I would like some color
      Deck: Pavers (but that is much later)
    I am meeting with the PB tonight to go over initial contracts etc. Does anyone had advice on equipment at this point? The PB uses MyBluePool equipment. I am going to ask him if I can provide the equipment and have him just install it.
    Pictures of site to come.
    Thanks!
    JD
    16 x 42 x 24 IG Vinyl True-L, 27,000 gallons, full width steel steps, 8' Cuddle cove swimout, 2 X Colorlogic 4.0 LEDs, Hayward Tristar 1 hp 2-speed pump, Hayward SwimClear C3025 Cartridge filter, Hayward Aqua-Plus PL-PLUS Controls + Chlorination, Hayward low-Nox 400K BTU heater, Tigershark QC, TF-100 test kit
    I don't know anything about equipment, but I do have one recommendation. Don't let the paver decision wait too long. Find out what the lead time is so you aren't left with a concrete shell that can't be finished until the pavers come in.
    Jun 2007
    SF Bay Area
    441
    kcj,
    Congratulations on your new pool.
    Pin the builder down on the pump size and make sure that he does not provide one with too much horsepower. Ask for hydraulic calculations. Especially since you do not have a spa (and hence the need for HP to power spa jets) high horsepower is not needed for circulation. You would need higher HP only sporadically for vacuuming or for your cleaner.
    Are you considering a 2-speed or variable speed pump? I don't know which state you are in, but California has recently outlawed new ore retrofit single-speed motors. You are required to use either two-speed or variable speed motors on all new and retrofit projects.
    Strongly consider an oversized filter. You will never regret having to clean an oversized filter only once or twice a year as compared to cleaning an "adequately sized" filter every month.
    Consider installing more than one light. I have never heard anyone complain about too much light on this forum, but lots of people complaining about not enough light. At least install the light niches even if you don't install lights in them right now.
    Consider the number and placement of skimmers. Many people only have one skimmer and with they had two. Consider the prevailing wind direction in where to place your skimmer. Nothing is worse than having one skimmer at one end of the pool and having the prevailing wind send all of the floating debris to the opposite end.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Richardson, TX
    287
    Welcome to TFP!
    As for the cleaner...get it now! I think it would be cheaper to install during a build than aftermarket. And you won't regret it, our Polaris is awesome!
    Good luck with everything!
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    Re: BigJD's Pool Build by the numbers
    Hello again folks! After almost a three year hiatus, we saved our pennies and I am back with an actual signed pool contract!
    New pool info:
    Pool: 16' X 42' X 24' True L, vinyl liner, steel full width steps and a swimout/cuddle cove
    Cleaner: later, most likely a tigershark
    Pump: Hayward Tristar 3/4 hp
    Filter: Hayward Cartridge
    Heater: most likely Hayward low nox
    Light: 1 (maybe 2) Colorlogics
    Tree removal company is coming to quote tomorrow. Pool contract date is 5/16 but we are hoping for last week in April!
    Here are some pics of the site:
    First from existing deck:
    Second reverse from the big rock in the above picture (the big rock will be the far corner of the L.
    donaldm823's Avatar
    Cape Coral, FL
    147
    I had solid granite 2 ft under the grass-so be prepared for extra cost of a rock crusher-cost me $2500 per day (3 days). I have a 60ft3 DE filter and love it. DE is cheap ($25 per box of 4 charges) and I backfulsh 1x per month. I wish I had one of the new Pentair variable speed pumps. Will save you a bundle in kwh costs (here is $0.15 per kwh). My 2hp pump single speed is costing me $60-80 per month and I run 10hr per day for my 30,000 gal (700ft3) pool. Have them run the one supply line for a Polaris 360, even if you do not buy initially. My 360 works great if I help it steer for max cleaning efficiency. It will clean my pool in less than 1 hr if I help steer and does a great job. The robotics were too exepsnive for my tastes.
    My best reconmendation is have them install a salt chlorinator. I have an autopilot. The best investment ever made. The only chemical I add during the pool year is acid to maintain the pH. I 'shock' the pool 2x per year (once when I open in April, and once just prior to closeing in Oct). It maintains the chlorine perfect, and the salt (3000ppm) is too low to taste but it gives the water a silky feel and the wife loves it for her hair!
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    susa's Avatar
    Oct 2010
    Deep South
    578
    get a variable speed pump (note: not simply a pump with 2,3,6 speeds but true variable speed). I deeply regret all the years and all the pools I've had where I purchased single speed systems.
    Saltwater system is a definite and it is included in the quote. I am fully prepared for the ledge issue, mentally and financially (although rock crushing here is $1500/day)
    How much of a benefit is the EcoStar over the Tristar? Is it worth the cost?
    Dec 2009
    Central Massachusetts
    2,690
    IMO, a VS pump is not worth the cost unless you are in an area that has a high electricity prices or live in an area where you keep the pool open and running year round. If your electric rates are reasnable and you close the pool 6-7 months out of the year, a 3/4 HP single speed or a 2 speed is plenty good. When i replace my 3/4 hayward super, I might look into a 2 speed, but for most people that want to save a bit on electricity, a 2 speed is fine. But thats just my opinion.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    The pool will be closed 7 months out of the year, our electricity is around $0.15 per kwh according to Hayward ....
    [attachment=0:1m49pxbv]hayward.jpg[/attachment:1m49pxbv]
    Those Hayward savings estimates for the EcoStar are optimistic. For most people a variable speed pump saves around 50% to 60%. I've seen variable speed installs with savings around 80%, but they are rare and invariably result from replacing a pump that was dramatically oversized to begin with. Getting paid back for the additional investment for a variable speed over a two speed with an electric rate around $0.15 and a pool season of about half the year is rather unlikely.
    Thanks Jason ... that's what I was thinking. Got one tree removal estimate today at $1600, less then I expected which rules.
    Mar 2007
    Ontario
    211
    We used city workers on their time off on a weekend for tree removel. They where cheap and fast.
    Not many insured tree serrvice guys around anymore, the insurance for them is costly.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Aug 2010
    MA
    173
    Not sure I'd want guys falling trees on my property without insurance.
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    Dec 2010
    San Diego, CA
    1,137
    Will you be adding solar? Or possibly in the future?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Only insured tree pro's for me thanks ... and we have tons of tree guys out here ... second tree quote at $1895
    Solar is a definite future possibility. rear of my house faces almost due south and I have a lot of roof ....
    30,431
    JD,
    I am impressed that you found and added to your old thread........I can't remember where I put my keys 10 minutes ago.
    Looks to me like you are off and running. The whole forum loves pictures and we are always ready to share our opinions.......sometimes even if they are not asked.
    Just kidding, the advice and level of professionalism on this forum is without equal. We're happy you came back to share your pool build.
    Third tree bid at $1550 ... ding ding ding we have a winner. Nice local guy too ... says he can do it next week ... pics will follow
  20. Back To Top    #20
    The trees are gone-zo ....
