Results 1 to 10 of 10
Thread: vaccum and skimmer intex kit
    My Vaccum and skimmer Intex pool doesnt work... since a week I vaccum my pool and it just enter bugs and things like that.. but not the dust... last week the little bag was heavy with all the dust......Im desperate ;(....my pool its complite of dust ... I also realized that the skimer doesnt work neither
    22,553
    Re: vaccum and skimmer intex kit
    Which model pump and filter do you have?
    What have you tried to get it working?
    I have a rectangular intex pool.. sand filter.. today the skimmer worked.. very well.. and the vaccum dont.. I realized that the dust its not keeping in the little bag... I was reading maybe I need to buy a new one.. I have almost ten months with that one.. I went to some stores here in Mexico.. and its imposible to find a new one.. I guess I have to wait to go to the US... I improvised with a socks and works a little bit.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Welcome to TFP!
    If you are trying to use the garden hose vacuum, I can tell you from experience it won't ever work very well. What model filter/pump do you have?
    You might try to find a long enough pool hose and plug it into your skimmer connection and use that for vacuuming.
    Thanks.. I have the crystal clear sand filter pump...wich its the pump that comes with the pool
    May 2012
    Baltimore, Maryland
    183
    Quote Originally Posted by Charlie_R
    Welcome to TFP!
    +1
    The garden hose venturi style vacuum is good for larger debris (leaves, twigs). It is not good for fine dust/silt/dead algee.
    You could adapt your garden hose vacuum head to be used with your sand filter pump. you would need a long vacuum hose which you need to attach to where you would tie the bag. block off the part where the garden hose connected. You could then use it as a suction style vacuum and use your filter to vacuum your pool, it would do a much better job then with the bag and garden hose setup.
    Modifying and using the vacuum head this way will filter the fine dust. Without the debris bag though the larger debris will get suck in your pre-filter basket and may require more frequent backwashes
    15'x4' Metal Frame Intex 3yo (2nd year winterized) 16" 2650gph intex sand filter, Thru wall skimmer, dual inlet/single outlet, 1000gph intex pump (heater) Solar Cover TF-100 testkit, TFPC
    thank u all.. I found a place here in Mexico where I can buy a debris bag not as the intex bag with the blue ring but Im gonna try.. I also bought a Pool Blaster Pool Blaster Max CG Pool Cleaner.. I hope to arrived soon and travel to the USA..
    Jun 2013
    Manitoba, Canada
    153
    Unfortunately the "dust" will still go through the bag mesh. You need to vac it through your filter. The pool blaster will pick up everyting else though and works good.
    All I did for mine was get a cheap pool vac hose, and a head for it (less than $30 total), then I went to Home Depot and bought a 4" PVC threaded PVC sewer pipe end cap. Drilled a hole the right size for the hose end to slip in. It threads onto the Intex inlet and allows me to use the vac through the filter. Does not have to be more than a half turn since the suction keep its in place anyways. Works great and cheap!
    Hello xanadu oh my God its a new language so u plug the hose with the pvc and then u leave the intex inlet ?? or u have to remove it??
    so I will have to buy the pool vac hose.. and look in home depot 4" PVC threaded PVC sewer pipe end cap...
    as I have a solar cover all the dust it is in my pool on the corners..
    thanks.
    Jun 2013
    Manitoba, Canada
    153
    The inlet on the pool, when you want to ues the vac, place the PVC adapter onto the inlet, then stick the hose into adapter (after you fill the hose with water otherwise you get an air lock in your pump).
    All I do is place the hose and vac head into the pool and turn in circles under the water to get the air our of the hose. Then keeping the hose under water, plug it into the adapter you threaded on. You need to get the air our of the hose first!
    I remove the adapter when I am done with the vac.
