Thread: Help... Display says Chlorinator OFF and No Flow!!!
    Not sure what to do. Water tested low on Chlorine, salt level and everything else apparently fine. Shocked several times and put Chlorine Tablets on skimmer. Does this mean salt is not producing chlorine? What's the quick fix? I appreciate the help!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Help... Display says Chlorinator OFF and No Flow!!!
    Welcome to tfp, poolidiotme
    What does you water look like?
    For us to be most helpful, we will need some details. See: http://www.troublefreepool.com/pool-...efore_you_post Specifically I am looking for test results and pool equipment details.
    That means the SWG cell is not getting enough water flow to produce chlorine, so the controller has turned off the SWG.
    Usually this is caused by something simple, like a clogged skimmer basket, or pump strainer basket, or dirty filter, or dirty manifold strainer screen (if your unit has a manifold strainer screen).
