Thread: hayward H250 heater curcit panel
    I have been told I have a bad digital panel on my Hayward H250 pool heater with electronic ignition, which is 9 years old. Can I by pass or jump the digital board in the control panel. The heater starts but does not light the burners. I have been told the problem is in the digital board, which is very expensive to replace. To be sure its the digital board I need to be able to by pass the board and start the heater.
    Hayward
    22,542
    Re: hayward H250 heater curcit panel
    I don't know that there is any way to bypass it and the heater still work.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Unless you have an automation system, you can not bypass the board. With automation, you could careless if the display is working as the automation system controls the temps.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
