Thread: I want a Pool Timer,Brand ? What to look for ??
    May 2013
    Richland,Michigan
    32
    I just purchased a home with a inground pool. I would like to add a timer to my filter/pump. I have no idea what to look for.
    Or what is considered a good brand. Recommendations ????
    I also have old school screw in fuse box. thinking of upgrading this also to breakers,,
    Should I upgrade the box while im in there ??
    thx
    jp
    30x18 Gunite inground pool with fiberglas side walls, 20k gallons, Sta Rite Sand filter .75hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: I want a Pool Timer,Brand ? What to look for ??
    Intermatic is the standard. They have some models that are just the guts, and fit into the breaker box. I'd upgrade if I was you - those screw in fuses aren't available with GFI, are they?
    May 2013
    Richland,Michigan
    32
    Thx on the intermatic timer,,
    Yea Screw in fuses are not very confidence Inspiring
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    http://www.amazon.com/Intermatic-PF1103 ... thermostat
    We like this one
    You probably wouldn't need one with the freeze protection thermostat in your climate. Down south we don't "close" our pools so we wanted that feature.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
