Thread: Raccoon scat
    Raccoon scat
    I have a swg in ground pool and had found raccoon scat on the steps. Raccoons 60-80 % carry raccoon round worms and the eggs in feces number in the millions. Chlorine doesn't kill them and if ingested they can lead to blindness organ damage and death, although rare. The CDC says empty the pool. My issue is there is no real information on the viability of the eggs in the water over time. If he was a problem pools, rivers, lakes across the us would be infected. I wrote to a raccoon habilitation facility and they said the the chlorine and uv should degrade the eggs over time maybe a month.
    Short of emptying the pool each time I may find scat on the pool steps I thought I'd install a uv system as well.
    Does anyone have any information?
    Thanks
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Raccoon scat
    Welcome to TFP!
    The CDC in this link also gives the option of 24 hours of filtration followed by backwashing/cleaning and removal/replacement of the filter media. You need to wear gloves and be careful with the cleaning. Their second option is to drain the pool, but basically the eggs are not so small as to not get caught in the filter so good circulation with filtration should remove them (as shown in this link the eggs are 80-85 Ám by 65-70 Ám in size so even sand filters can capture them). 7 turnovers would filter 99.9% of the pool water (with ideal circulation and mixing) so 24 hours implies a 3.4 hour turnover. If your turnover is longer, then filter for longer.
    Re: Raccoon scat
    The pool had run for about 7 hours a day for a week. I back washed the filter and cleaned out and replaced the sand. Thanks for the advice....
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Raccoon scat
    Well, this may not be something you want to do, but what about trapping the coons? If they were getting in my pool, I'd be fighting them with all means necessary.
    Essential Links:
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Raccoon scat
    Wow didn't know any of this.
    I recently got a motion activated sprinkler to keep our dogs away from an area of the yard. It works great!
    Like this http://www.amazon.com/Contech-CRO101-Sc ... n+detector
    Now i want two more.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
