Results 1 to 8 of 8
Thread: My little friend!
    Jun 2011
    East Texas
    27
    My little friend!
    Water has been perfect. Why did my visitor decide to join me? He is also beige not brown and all alone....[attachment=0:1gpp8qtf]image.jpg[/attachment:1gpp8qtf]
    Current 24' x 52" Intex W/ swg and sandfilter
    12,500 Gal. above ground.
    About to put my big girl panties on
    and get a real pool. :)
    Real pool never happened,,, ripped off. :-(
    TF100, no speed stir.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: My little friend!
    Do you have any valid test numbers ?
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    It happens sometimes. Maintaining proper FC usually usually repels bugs from getting in the water. In cases where a bit more "persuasion" is needed, borates can help.
    Jun 2011
    East Texas
    27
    Yep today before cleaning. I know oh and all high I added acid again.
    FC 9. (Need to trurn off swg a bit)
    Ph 8
    Alk 160
    Haven't tested cya recently it was 80
    Didn't do cc last week was 0
    Jun 2011
    East Texas
    27
    Last time I tested, couple months ago my borates were at 50. Think I should raise it?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by wildchilde
    No.
    You're done SLAMing when:
    Jun 2012
    Howell, NJ
    977
    I think this just happens sometimes. For me, this year I have been having those bugs that walk on top of the water. I don't think they bite, so I am not too concerned.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Most of those underwater bugs eat algae and other organics. Since you keep a clean pool free of organics, the bugs move on fairly quickly. Most often within a few hours.
