Thread: Error Code on Jandy AquaPure 1400
    Hi,
    I just replaced my Jandy AquaPure 1400 cell and am getting this error:
    172 Flow Sensor service condition or flow sensor is
    unplugged.
    Of course, the 'troubleshooting' says to call a service professional.
    Any trouble shooting tips before I bring someone out? I'll be happy to post pics of my connections, etc if that helps.
    Lynn
    12000 Gallon Freeform Pool
    SWG
    Jandy AquaPure 1400
    Leslie's DPD Complete Chlorine Kit + FAS/DPD Chlorine Tester and Swirler from TFP.com
    Tree covered lot - cottonwoods and crepe myrtles. Great shade during the summer, miserable fall cleaning leaves from the pool.
    Re: Error Code on Jandy AquaPure 1400
    That could be a couple of different things. If everything was working recently, the two most likely are 1) The cable between the control unit and the flow sensor has been cut or unplugged. 2) The flow sensor is broken.
    Jun 2011
    Long Beach, CA
    2,790
    Make sure the tri-sensor cable is plugged in securely. I was having intermittent problems with flow issues a while back and it ended up the tri-sensor cable was not plugged in securely.
    Thanks for the advice.
    Ping, I'll double check the cable.
    Jason, I hope the flow sensor isn't broken, it's a brand new part! And thanks for creating the Pool Calculator. It's awesome.
    SWG
    Jandy AquaPure 1400
    I checked everything and re-pressed and held the calibration button on the Tri-Sensor adapter last night. I didn't think it did anything, but when I went back later, the service button and codes were gone. I'll continue to keep an eye on everything in the hopes that all is fine.
    Thanks for the suggestions.
    Lynn
    SWG
    Jandy AquaPure 1400
