Results 1 to 11 of 11
Thread: Broken DE grids
    Jan 2013
    Houston, TX
    1,079
    Broken DE grids
    Finally got around to opening up the DE filter to get it cleaned out (I think the prior owners never cleaned it) and low and behold 5 of the 8 grids are broken. I know I need to replace them, the question I have is what is the impact of putting bum grids back in? I don't have the patience to deal with Leslies and am going to order them ... sometime in the next month ... from poolsupplyworld.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Broken DE grids
    How bad are they broken ? Might only effect filtration alittle until you can get new ones.
    Jeff
    Feb 2008
    Denton, TX
    5,061
    Re: Broken DE grids
    Well, broken grids mean that your pool will have DE pumped into it when the pump is on since there is nothing stopping it from happening. This may mean a lot or a little bit of DE in your water, but you'll never be able to get it as clean as you could.
    Jan 2013
    Houston, TX
    1,079
    Re: Broken DE grids
    No holes in the grid fabric. Just broken grid plastic at the bottoms. Ranging from 3-8 inches at the corners.[attachment=1:3m4ozcf4]ImageUploadedByTapatalk 21373743822.963891.jpg[/attachment:3m4ozcf4][attachment=0:3m4ozcf4]ImageUploadedByTapatalk 21373743848.714328.jpg[/attachment:3m4ozcf4]
    Jan 2013
    Houston, TX
    1,079
    Re: Broken DE grids
    Opinions on dry de in the skimmer vs slurry?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Broken DE grids
    I put it in dry in the skimmer slowly.
    Jeff
    Jun 2013
    SpringHill FL
    415
    Re: Broken DE grids
    If the screens are intact you will not have many issues running the filter until you can replace them
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jan 2013
    Houston, TX
    1,079
    Re: Broken DE grids
    Thanks. Practicing POP while I refill. Left it on backwash a bit too long.
    [attachment=0:3cwefxtm]ImageUploadedByTapatalk 21373747887.352748.jpg[/attachment:3cwefxtm]
    Jun 2013
    SpringHill FL
    415
    Re: Broken DE grids
    I also add dry to the skimmer ( much slower than before I found TFP)
    Nathan
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Broken DE grids
    Quote Originally Posted by karmabiker
    [attachment=0:4odujfft]ImageUploadedByTapatalk 21373747887.352748.jpg[/attachment:4odujfft]
    Sent from my iPhone using Tapatalk 2
    Nice!!!
    Jeff
    Jan 2013
    Houston, TX
    1,079
    Re: Broken DE grids
    And just for fun ... The before picture...
    [attachment=2:1ihtjc2u]ImageUploadedByTapatalk 21373952600.742622.jpg[/attachment:1ihtjc2u][attachment=1:1ihtjc2u]ImageUploadedByTapatalk 21373952617.534404.jpg[/attachment:1ihtjc2u][attachment=0:1ihtjc2u]ImageUploadedByTapatalk 21373952637.120600.jpg[/attachment:1ihtjc2u]
