Thread: help - wiring new pump motor
    In the middle of installing a new UST10172 motor on a pump. Ready to hook it up but there are no wiring diagrams provided. I know these are usually from the factory at 230V but I have a 115v installation.
    Anyone know how to change this? It's not obvious to me by looking at the existing wiring and the old motor is just a bit different.
    Thanks
    TF-100 Test kit, 24,000 gal. free form Vinyl. mybluepool AC-600 SWG, STA-RITE S7MD60 DE filter, 3/4 HP STA-RITE MPRA6D pump, Polaris 280 w/booster, Raypack Propane heater, Looplock mesh cover; All located in New England.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: help - wiring new pump motor
    Does the dataplate on the new motor indicate it can be run on 120/240? If not, then you will have to run a new line from a 240 (two pole) circuit breaker.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    There's no diagram on the motor?
    Try this link: http://www.bestbuypoolsupply.com/media/motormanual.pdf
    You got it! The diagram was right on the motor. Pump could be run in either 230 or 115 mode and all I had to do was turn a lever on the motor. Pump is now up and running fine.
    Thanks for helping!
