Results 1 to 7 of 7
Thread: Lowering ta with minimal effect on ph
    I know tfp experts,admins and moderators are going to jump all over this but, oceanstate job lots has ph minus with instructions on the back for lowering ta with minimal effect on ph. I will tell you it worked great. Lowered ta by 15 with almost no movement on ph. Got tired of the aeration process.
    21000 gal vinyl lined in ground
    36 sq. ft. DE filter with Hayward 1.5hp VSP
    SWG chlorine
    Massachusetts
    30,402
    Re: pH and TA
    Can you tell us the product name and brand?
    Re: Lowering ta with minimal effect on ph
    I would love to see these instructions.
    rharlowjr's Avatar
    Jun 2013
    Brooklyn, CT
    14
    The label says it "lowers pH and TA", although I admit I didn't read the entire label
    It's sodium bisulfate, by pool mate I believe
    --Russ
    Brooklyn, CT
    AG round, 24' x 3.5' deep, 13k gal, vinyl-lined pool, sand filter--31.5 gpm, 1.0 hp pump
    All forms of acid lower both PH and TA. Sodium bisulfate is generally called dry acid around here, though it goes by a wide variety of brand names.
    rharlowjr's Avatar
    Jun 2013
    Brooklyn, CT
    14
    I just happened to see the post before I went to Ocean State Job Lot (same store OP bought it) and thought I'd help fill in some blanks when I saw the product on the shelf. I just wanted to note the very first line of the instructions:
    Quote Originally Posted by rharlowjr
    ...even though OP states a product named pH Minus
    Quote Originally Posted by Dier74
    has instructions on the back for lowering ta with minimal effect on ph.
    --Russ
    Brooklyn, CT
    30,402
    Dier74,
    Any update on those instructions or at least a product description and the brand name?
