Results 1 to 7 of 7
Thread: First competition this weekend....
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    So we had our first comp, it was the second in the Ontario Series (We had to miss the first)
    Great weather, 29-32 C all weekend. Our team has 2 members this year, last year we had 3.
    Its a typical competion with the usual categories, beef brisket, pork shoulder, ribs and chicken.
    Last year we were the Ontario Series Champions and had the honor of competing at the Jack Daniels World Invitational down in Lunchburg, TN.
    We didn't do overly bad, but when trying new recipes and with one less member, its like starting over.
    We ended 19th overall out of 26.
    4th place ribs
    24th place chicken (we thought it was the best yet, but one out of 6 judges did not)
    12th place brisket
    22nd place shoulder
    all in all it was a great weekend.
    Next up is the Canadian Open in July!
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Butterfly's Avatar
    South Carolina
    10,045
    Congratulations!
    I'm getting hungry..........
    You're done SLAMing when:
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I'd love to have your receipe for the brisket. Nothing beats a good beef brisket IMO
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    there it not much for a recipe, pick your favourite beef rub (if you need ideas for that, let me know).. Slather the brisket in mustard, or a brisket slather (mustard + spices etc) and put on a 250 degree smoker. For brisket we used some cherry wood, some apple, some Jamaican run infused woodscuits, some bourbon infused woodscuits.
    Our 12lb brisket took 13 hours, then it was wrapped twice in foil, then a towl and stuck in a cooler for 3 hours. Remove, slice and serve.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by jjparrish
    Congratulations!
    Ditto....
    Re: First competition this weekend....
    Congratulations,
    I miss competition BBQ, but not the all-nighters they usually turned in to. Brisket is one of our favorites and I have a bit different twist to the technique. I mustard up, add rub and smoke heavily at 225F for three hours using hickory. I then put it in a high-temp bag, wrap with saran, then foil and finish in the oven at 225F until 210F internal temperature. I did a quick video, including a tip on separating the point from the blade here.
    http://www.tumbleweedglass.com/brisket.html
    Steve
    Tumbleweed Glass Studio
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Thats cool! I always have trouble with the separation. We can't use oven's tho at competitions.
    We smoke on a stick burner for 2-3 hours, then put the briskets in the Traeger for the night so we can get some sleep.
