Thread: Mastertemp 400- only works when I bypass fireman switch
    Hi Folks
    My MT 400 will only work when I manually operate it by bypassing the compupool controller. I jumped the fireman switch which means it in the controller or another sensor, correct? How can I confirm what the problem is?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Mastertemp 400- only works when I bypass fireman switch
    I can't help, but I know there are people here who can!
    ps0303's Avatar
    Jul 2011
    FL
    3,692
    So your controller is wired into the fireman's switch, very typical setup. Check the wire that leads from the fireman's switch to the controller. Possible broken/disconnected wire.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
