Results 1 to 13 of 13
Thread: OCLT: FC is higher in the morning.
    Apr 2013
    South California
    69
    After shocking process about a week, I did perform OCLT yesterday and today. And the result is confusing.
    Yesterday result:
    FC = 27 (the night before)
    FC = 29 (in the morning)
    I was confused so I did another one just this morning.
    FC = 22.5 (last night)
    FC = 25 (morning)
    What is possibility here? bad patch of reagent?
    I followed exactly at these step:
    pool-school/overnight_fc_test
    Edit: I want to add something. I have the kit K-2006 but the R-0871 was out after 2 days, so I ordered the reagent. The result from the new R-871. That was why I asked may be because of bad reagent?
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    Jun 2013
    SpringHill FL
    415
    Re: OCLT: FC is higher in the morning.
    Your swg producing chlorine with no loss at night would be my guess( unless you turned it off)
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Did you leave the SWG running overnight?
    30,421
    Chlorine cannot be increased in your pool unless you add it. Are you running your SWG or have pucks adding chlorine?
    Apr 2013
    South California
    69
    SWG is off at all time of the process, and no pucks, nothing in it.
    Installed 4/29/13
    Sep 2009
    Greentown, IN
    914
    How long did you let the pump run before you took your test at night?
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Sep 2009
    Greentown, IN
    914
    ... after adding chlorine I mean
    Test kits compared
    Purchase test kits
    Apr 2013
    South California
    69
    Quote Originally Posted by Suziqzer
    The pump run 24/7
    Installed 4/29/13
    Jan 2013
    Houston, TX
    1,079
    I would double check that SWG...
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jun 2012
    Howell, NJ
    977
    I had this same thing once and just attributed it to testing error. Since you had it happen twice, I think there is something else going on. You had the filter running for at least 1/2 hour after adding chlorine and before doing the night test, correct?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Apr 2013
    South California
    69
    I know it's weird. The first time could be understandable because the pump was running, adding chlorine so there was may be the errors. But for second time, I turned off the pump and not adding chlorine since yesterday long before I took the measure. Anyway, I would keep my eyes on this today.
    The SWG was off during shocking process.
    Installed 4/29/13
    Smykowski's Avatar
    Sep 2011
    3,065
    You never answered Suzie's question, and I agree with her hunch. After putting your evening dose in, wait at least 30 min (in this case more might be better) before doing the test. If it's not mixed well enough in the evening, but it is mixed well enough in the morning, that could be the sourceof the discrepancy.
    Jun 2011
    Long Beach, CA
    2,789
    A couple more things to watch for, make sure you get the water sample from the same place and depth in the pool, and that you put in enough powder in the test. Two generous scoops of powder should do it.
