Thread: CYA: calulated vs. measured
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    At the beginning of the season, just after opening, my CYA measured at zero. I calculated I need about 12 lBs of CYA to get my 25000 gals up to 60 ppm CYA. I am still reading about 30-40 with my K-2006 and Color Q tests. Should I add more or just let it be?
    Thanks!
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I thought I read that CYA can be higher with SWG?
    When did you add it? It can take a full week to completely dissolve and register....
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I added it about a month ago. I was headed for 80 ppm but I thought I would shoot for 60 ppm first so I could sneak up on it. All other numbers are good so I'm not sure why it's so low, didn't clean out the carts after adding.
    30,426
    Triple,
    Do you have a diving end in your pool? (i.e. is your gallonage correct?)
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Yes, my deep end is about 9 feet. I got my gallon numbers when the pool was built last year from the water company that filled it. I guess they could have been wrong and I have more water than I thought.
    Maybe I'll just add a bit more and see where I end up since I need more than the 60 ppm I was shooting for.
    30,426
    Yeah, you've got 30-33k. CYA issue solved.
