Thread: CYA test results
    Fairfax Station, VA
    52
    CYA test results
    I have TFTtestkits.net CYA view tube test kit. I consistently get around value of 65 (I have an SWG). The R-0013 reagent is fresh. I brought the water to Leslies and the value was 100 on the slide test they use. I looked at the sample myself and was in agreement with their reading. Why is there such a large discrepancy between the results? Which is more reliable?
    35K gallon plaster IGP, free form, spa with spill-over; Sta-Rite 2HP pump; KDI American 48sq.ft., 144GPM DE filter; Pentair MiniMax heater; pressure side The PoolCleaner; Circupool RJ45
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: CYA test results
    Quote Originally Posted by mrhappye
    Indoor versus outdoor light would be my guess. The dimmer the light, the sooner the dot disappears, the higher the reading.
    Since the TF100 comes with a generous supply of R-0013, try the test again. Then carry it inside and try it under different lighting. You've got the Junior Scientist Play Set, so experiment!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    We assume you bought the test kit TFP recommends for a reason. Trust your own testing when performed as prescribed. Reasons: Testing performed mostly by teens........test performed inside rather than daylight........testing equipment not cleaned properly or calibrated enough or properly.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    The test should be read in strong sunlight, not under fluorescent lights. This is one of the reasons I think pool stores often get CYA readings that are way off. If your pool has been responding to chemical adjustments predictably with your test results then that is the testing you should trust. How does your water look?
    Love TFP? Become a
    TFP Supporter!
    Sep 2009
    Greentown, IN
    914
    Has your SWG been keeping up like you expect? Did you watch them do the entire test, or just the reading?
    I would go home and do the test again myself just to be cautious, but if everything else is working the way it should and your tested at home as you expected. I suspect theirs wasn't correct.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
