Results 1 to 15 of 15
Thread: flooded pool
    Jun 2008
    Oshkosh/WI
    21
    flooded pool
    We got about 3.5" of rain yesterday in Wisconsin and my neighbor's lawn flooded so much it overflowed the patio slab and ran into my inground pool. Now what? My nice clean pool water is now a muddy mess. The water is brown and the suspended dirt is not settling to the bottom like I hoped it would so I could vac most of the mud out.
    Is it even worth it to attempt to run my sand filter and filter it out or should I just drain it and refill (ugh!).
    Any help is most appreciated (especially by my kids)!
    Pool Spa Combo: 16K gallon oval inground pool / 700 gallon spa
    Pump: Pentair VS / Filter: Sand/ Heater: Pentair MasterTemp 300K BTU
    SWG: Pentair Intellichlor 40 / Controls: Pentair EasyTouch
    Other info: Equipment located in the basement
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I'm so sorry! Someone with more experience with this will be along shortly to advise. They will want to know your pool equipment and the size, etc.
    Do you have a test kit for testing your pool water?
    Where in Wisconsin?
    Welcome to TFP!
    It all depends on how much dirt actually got in. If you have several inches of mud on the bottom then you might want to drain, but far more likely you have just a thin layer of dirt that will be fairly easy to filter and vacuum out.
    Make sure you maintain your chlorine level. All of those contaminates will consume some extra chlorine. Vacuum up as much as you can and let the filter do it's job. Keep an eye on the filter pressure and backwash as needed.
    With a little work your pool should be back to normal in less than a week.
    Jun 2008
    Oshkosh/WI
    21
    Thanks for the quick responses!
    This is a 17K gallon inground plaster pool with a sand filter.
    I was reluctant to just run the pump/filter and then end up draining it anyway. I don't think there is too much actual mud to deal with, just very dirty water. The water was runoff from the street and the lawn etc.
    I will try shocking it well tonight while running the filter and backwashing frequently.
    krcossin's Avatar
    Detroit Burbs
    113
    I would vacuum to waste until the water level is just below your middle. Then run the pump 24 hours for a few days, keep chlorine level high, backwash/clean filter right after.
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    Mar 2008
    Hatfield, PA
    259
    I had this happen. It looked *awful* but sure enough in less than 24 hours with my DE filter the water was sparkling clear. It was all suspended and all filtered out without vacuuming.
    Oct 2007
    Valrico, FL
    542
    With flooded and saturated ground, be careful of pumping your pool down too far as it can float.Then you have problems big time!
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    ktdave's Avatar
    Katy, TX
    888
    The filter should take care of the muddy mess. You may need to think about the future, in regard to drainage from your neighbor's yard. Such as a berm or french drain system, etc. so that you can minimize this occurance.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Jun 2007
    SF Bay Area
    441
    ktdave,
    I would think that this would be the neighbor's responsibility to control runoff from his property.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Jun 2008
    Oshkosh/WI
    21
    Thanks again for all the rapid and helpful replies.
    It is frustrating to just get going on the short summer swim season only to have this setback. At least my basement is dry which was a problem for many around here in this heavy rain.
    I am looking at options to block this from happening again.
    I also ran home at lunch and fired up the pump/filter and dumped 2.5 gallons of bleach in. I hope to see improvement by the time I get home tonight.
    ktdave's Avatar
    Katy, TX
    888
    Quote Originally Posted by Titanium
    ktdave,
    Titanium
    Just rhetoric,
    I have no experience in such situations.
    Pool School
    TF Test Kits
    Mar 2008
    Wake Forest, NC
    128
    I had an inch of clay wash into my pool the first year. I had just finished back filling a retaining wall when a storm came up. It washed all my fill into the pool. I vac'd to waste filled over and over again. I could not do more than one8 foot X vac head wide pass before the PSI went way high.
    Fill to the highest point you can and then vac to waste as far as you can. I also replaced all the sand in the filter when it was clear to get any clay that may have been left behind.
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
    Jun 2008
    Oshkosh/WI
    21
    Well the pump has been running constantly now for 20 hrs and the water just looks slightly better. It still looks like a muddy pond. I have backflushed a couple of times though the pressure was only somewhat elevated each time. I have shocked it with bleach. I have not vacuumed yet because I can't see the bottom.
    Questions:
    1) Should I vacuum to waste or just wait till the water clears a bit?
    2) Would flocculant help speed the process? Is there a floc made for this suspended dirt?
    3) Should I consider running my Aquabot Turbo Jet cleaner with the fine filter bag, or would this be a bad idea (hard on the robot)?
    Thanks!!
    Mar 2008
    Hatfield, PA
    259
    Re: flooded pool
    I have a feeling I got a lot less stuff in my pool then you did. I would simply just have patience. And I would also wait to backwash until the filter pressure is much higher and the flow is visibly reduced. Reason is is because a slightly dirty filter filters better. In my case, I cleaned up the whole mess without backwashing once. But I didn't have a tremendous amount of actual soil in the pool. It just LOOKED bad. Can't give you any advice on the robot, but I don't have one. My first thought is to use the robot only for what it is for - maintenance cleaning and scrubbing of walls and bottom for normal debris. Your regular pool filter is more up to the job of cleaning the muck.
    Aug 2007
    Northeastern Ohio
    178
    Re: flooded pool
    I had a similar issue to start the season. I attempted to fill my 30k pool (which was half empty) with a garden hose (I have well water). The well pump started sucking up dirt and when I woke up the next morning, my pool was a solid brown color. I was able to filter it all out with my DE filter.
    For the first few days, I was bumping the filter once an hour (when I was awake). It took 2 DE backwashes before I could see the bottom. Then I vacuumed the settled dirt up, which required a filter dump after about every 4 passes with the vac head.
    Two more DE backwashes and it was back to clean and clear. A huge PITA, but doable.
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
