Results 1 to 17 of 17
Thread: No timer on pump
    vanessadickson's Avatar
    Jun 2012
    Kentucky
    61
    No timer on pump
    I dont have a timer on my pump and swg, it just runs 24/7. Pool is open May 30- Sept 15.
    Is that a bad thing?
    Alk 75
    ph7.5
    fc 6
    cal 220
    cya 45
    38,900 gal., UG, vinyl, SWG, Hayward w/T-15, 1.0HP pump, sand filter, Aquabot Turbo-T
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: No timer on pump
    That's probably overkill. You should get a timer. Intermatic are very good timers You can cut run time way down and save a ton of electricity.
    Pool school has an article on determining pump run time. Check it out.
    Jeff
    22,551
    Quote Originally Posted by vanessadickson
    only for your pocket book!
    As pwr said, you'll save some money by getting a timer.
    Jun 2012
    Kentucky
    61
    Yes, good call, Bama, hahaha.
    My real question is the actual cost to run the pump, so I can figure cost savings to install a timer (they are pretty cheap, but then there is the electrician....)
    I bet there is an electricity version of chemgeek ("voltgeek"?) on this site who would be able to calculate the cost to run my pump, on an hourly basis. Id be most grateful!
    Here is my info:
    Energy cost: $0.092425 per kWh
    Equipment: Hayward pump model SP2610x5
    Motor is UST1102, 1HP, that lists volts 115/230
    There are a bunch of other numbers on there that I dont know what they mean I can give you if needed. THANKS!!!!
    V
    Jun 2012
    Kentucky
    61
    PS-running on 220, not 110
    22,551
    Do you know how many amps it actually draws?
    If not we can use the data plate amps.
    Jan 2013
    Houston, TX
    1,079
    So 7.5 amps times 220v equals 1,650 watts. Divide by 1000 to get 1.65kw multiply by 24 for a 24h run time to get 65.34 kwh.
    65.34 kwh times .09 as an energy cost puts it at about $5.88 a day to run the pump at max load.
    These calculations are based on a 7.5 amp load which is the max load for that pump. Reality is probably something south of 7.5 amps. If you can get a VOM and get your actual amp draw we can get a better figure.
    As a reference point my 16k in ground costs under a dollar a day to run with a 2 speed pump and a shorter run time.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jan 2013
    Houston, TX
    1,079
    And what Dave said...
    Jun 2012
    Kentucky
    61
    Great info, thanks! I dont know the actual amp draw, as I dont have one of those thingys that measures (ampmeter or some such?) Anyway, having the max number is what I need to sort out potential savings, (and also let my green freak flag fly) thanks so much.
    You guys truly are the best!
    Jun 2012
    Kentucky
    61
    Hubbie wants to know whether best to install inside an outbuilding at the breaker or next to pump? Also, wants to know what are the better quality timers bc. he hates replacing stuff.
    (he's really impressed with "my" knowledge in this area, should I reveal that TFP is my source, or let him just go on thinking I've become a chemist and electrician without his knowledge after 13 years of marriage?)
    Jan 2013
    Houston, TX
    1,079
    Intermatic makes the most serviceable / reliable / cost effective timer. The enclosure is rated for outdoor so ... Personal preference on that one.
    I think this is the ticket ... http://m.poolsupplyworld.com/Intermatic ... 10004R.htm
    On an iPhone and can't confirm.
    You might actually save more by doing a motor replacement with a 2 speed because of the non linear nature of motor power consumption. Ideally timer and 2 speed ... But that depends n budget.
    Jan 2013
    Houston, TX
    1,079
    Maybe a handle change is in order. I like volt geek
    May 2009
    Trenton NJ
    497
    Quote Originally Posted by karmabiker
    Sent from my iPhone using Tapatalk 2
    Yeah man....nice breakdown. $5.88 a day. That's a lot of money every month,plus air conditioner running all summer too.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Jun 2012
    Kentucky
    61
    ....except I live in a shady old farmhouse that doesn't need AC. Ahhh, those cool breezes on the back porch....
    Back to topic. Monthly, that's a $176 total cost to run at 24/7, and if I run it half the time I can save $88/month. With the price of the recommended timer at $175 and $100 for the electrician, I can probably justify it in 3 months of elect. savings.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job
    Jeff
    Jan 2013
    Houston, TX
    1,079
    Take a look at the 2 speed option as well. You could end up at under $30 a month. (mine at 10 cents calcs out to about $28)
    Jun 2012
    Kentucky
    61
    I will! Thanks so much, Volt Geek!
