Results 1 to 9 of 9
Thread: 2speed pump?
    May 2009
    Trenton NJ
    497
    2speed pump?
    I have one.....funny thing is I can't hear the difference between the 2 speeds. I guess the only way to tell is up is high n push switch down for low.
    What's better....run on high for 6 hrs or on low for 12 hrs.?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: 2speed pump?
    You can tell the difference by the pressure reading on your filter gauge or put your hand in front of the return.
    I run mine on low for six hours and water is crystal.
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: 2speed pump?
    Forgot to mention I use high when adding bleach to mix good and when I need better skimming.
    So I probably run pump for 8 hrs.
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: 2speed pump?
    +1 for running at low speed. Filtration is likely to be better. You can run it on low and you may be able to run it for less time than you think. Follow the suggestions in this article: Determine Pump Run Time
    When it comes time to replace my single-speed pump motor (which I may do before it wears out), about the only time I would run it on high speed is immediately after adding chemicals and when I am vacuuming with the Polaris.
    The only strange thing from your post is that I would expect to hear a noticeable reduction in noise when running at low speed vs. high speed.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: 2speed pump?
    You would think you would hear the difference or that's one quiet pump.
    Jeff
    May 2009
    Trenton NJ
    497
    Re: 2speed pump?
    Well.....it's called whisperflow pump
    May 2009
    Trenton NJ
    497
    Re: 2speed pump?
    You know....I may have to go back and see how I wired it. Is it possible I wired it for single speed?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: 2speed pump?
    Quote Originally Posted by ethany
    It is definitely worth taking another look at if there is a shadow of a doubt.
    Jun 2007
    New Jersey
    653
    Re: 2speed pump?
    I put a 2speed on my WhisperFlo. The difference is dramatic. On low, I have to touch it to tell if it's running. On high, I can definitely hear it as soon as I get around the barrier fence. I'd recheck your wiring.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
