Results 1 to 16 of 16
Thread: New intex swg with ozone
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Split from this thread due to my derailment of that thread.
    Quote Originally Posted by yister
    There's the new intex swg/ozone unit as well. I was looking into some UV unit, but came across the intex unit. Just at the same time my old swg unit started leaking at a seam. I just wanted some extra protection besides clorine for the pool/kids. It injects air thru a venturi, so you get aeriation as well.
    Do you have this new swg yet?
    Re: Ionizer for 24' AGP
    Yes I do, I've been running it for aweek or so. My cya level was insuffient, so the performance is still being observed. I had to add bleach 2 days ago and this morning the fc level was good. So, I'm guessing it's working properly now. I preffer this design from my old one as it had a glued joint where the plate was. This one is I guess the same plumming as the swg units sold now with only threaded joints. The water's been crystal clear and all the level's are fine. For $80 you can't go wrong, it does add alot of air into the pool from the venturi though.
    Intex 16'x48"
    Intex sand filter, ozone SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Where is the venturi located? I can't seem to find it in pics on the web.
    Jun 2012
    Howell, NJ
    977
    This sounds like it could really help me keep my pH up. I searched, but couldn't find this particular SWG. Does anyone have a link? Also, do you think it could handle a 24' pool?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Intex claims it is good up to 15000 gallons. More importantly, it is speced to put out 11 gr/hr of chlorine (max spec) which should in theory support your pool (thats about 0.22 FC/hr in your pool). The unknown with this unit is the ozone and if it will actually cause a higher demand for chlorine...it may. In addition, if it has a venturi as suggested, the ph rise may be very high since the nature of the swg also causes a ph rise.
    One other potential negative is it looks like it adds 4 extra 90 degree turns to the water.
    Jun 2012
    Howell, NJ
    977
    The pH rise I am not too concerned about, because my fill water is a pH of 4.5, so I am already always raising that. I have a solar cover that is on most of the day, so my FC loss per day is usually around 1 ppm. I can't find this on Google, does anyone have a link they could share?
    John
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Unfortunately intex does not have much info on their website about it yet.
    Jun 2012
    Howell, NJ
    977
    Thanks for those links. Since this is new technology, I think I will wait for some other people to try it for a while. That said, if it doesn't increase chlorine demand, and lasts a reasonably long time, I think in the long run this would be cheaper than bleach for me.
    John
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It does look like the izone generator module is replaceable, so maybe it can be taken out and not put back in...but I am not sure about that. As has been said, a typical outdoor residential pool has no need for ozone if it is properly chlorinated.
    The ozone/venturi part is under the plastic shell next to the traditional controller, clean design. The only bad thing is even with the unit off, the venturi always putting out air. Good for keeping PH high with low TA and kids like bubbles. I have a small 14' ultra and been running for 4 hrs a day only hooked up to 2650 sand filter. Pic.
    Intex 16'x48"
    Jun 2012
    Howell, NJ
    977
    Yeah, I'm not crazy about the ozone part. That said, at $80, even if it increases chlorine demand a bit, this seems like it could be a good deal for me. Do you know if this SWG contains copper bars like the other ones do?
    John
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by JohnN
    It appears to not have copper anymore (thank goodness).
    That stinks.
    If you take out the ozone module, will the system still run? If it does, could you just plug the venturi?
    22,539
    Hey guys let's move this side conversation somewhere else if you don't mind. Poor Leslie has gotten completely lost in the fray.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New intex swg with ozone
    Good point Bama...I am the culprit here ...topic split.
    Jun 2012
    Howell, NJ
    977
    I was almost going to start a separate topic for this. Thanks for splitting it.
    John
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    yister (or any one else with it), any comments on how this new intex swg/ozone unit worked for you this season?
