Thread: Sagging Pool Liner - 1 year old
    [attachment=0:lll6id7e]IMG_5016.jpg[/attachment:lll6id7e]
    Hi Guys,
    Do you think this liner (installed a year ago) has a liner lock? I read about them on the site and doubt one was installed. Using this post
    pool-liner-sagging-t49015.html do you think I could use the boiling water trick to lift up this spot? Then I think I should have a liner lock installed instead of the coins the pool company used in between to hold it up. Could my handyman install a liner lock or would I need a pool professional? As someone said on this site -- $45 for a liner lock is chump change and should have been installed!
    Thanks as always for your advice,
    Karen
    16x32" IGP Vinyl liner 18,000 gal.
    Pentair IntelliFlo Variable Speed Programmable Pump
    Pentair sand filter hard plumbed.
    Pentair IntelliChlor Electronic Chlorine Generator
    Poolvergnuegen 2-Wheel Suction-Side pool cleaner, Diver Dave TF100 Test Kit/Speed Stir
    22,550
    Re: Sagging Pool Liner - 1 year old
    I'm pretty sure that it doesn't. That should be pretty easy to fix and install the liner lock.
