Thread: Today's Test Results
    Once I hit all the adjustments for chemistry levels, I will be a "pro", but this is still my third day, so bear with me.
    6/9/08
    FC......3.5
    CC.....0
    TC.....3.5
    pH.....7.7
    TA.....130
    CYA.....30
    I realize my TA is creeping up and my pH is higher today. I added my initial CYA liquid stabilizer yesterday and bleach.
    What would be my next step?
    I see on BBB muriatic acid will lower pH and TA levels. Is this a liquid? Found in hardware store?
    Based on the pool calculator is says I should add 17oz of MA. Would it be best to add 1/2 of this first and retest?
    18x36 IG Vinyl Grecian Lazy L (20k gallons) ~ Whisperflo DS 2.0HP pump ~ QuadDE100 filter ~ Autopilot SWG DIG-60 ~ (7) 4x16 solar panels
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, Muratic acid can be found in hardware stores.
    Sounds like a safe route to me....
    Butterfly's Avatar
    South Carolina
    10,045
    You're doing a great job.
    I agree w/FPM re: muriatic acid. Since you have a SWG, I'd buy a couple gallons at the time
    Just in case you haven't found it, here's a sticky for your SWG water balancing:
    “Water Balance Tips for a SWG” by Waterbear: http://www.troublefreepool.com/sticky.php?s=3663
    Here's a sticky on "Lowering your TA" by Waterbear: http://www.troublefreepool.com/sticky.php?s=5341
    You're done SLAMing when:
