Thread: Do I add cellulose after each backwash?
    Jun 2013
    Fortson Georgia
    51
    I'm nearing the end of" Slamming" my pool. I added cellulose to help my sand filter clear the pool. Do I need to add it each time I back wash? I am only back washing when filter pressure increases by 25%. Pressure increased after about 40 min of circulating-I backwashed & resumed filtering. I wanted to be sure I was to add more cellulose after each backwash.
    Starla
    1993 22x42(40K gal) vinyl Grecian, inground
    Aquarite SWG, Hayward s244t sand filter & 1hp Hayward pump, polaris 380 w/booster pump and dedicated return.
    2 skimmer baskets, main drain, 3 returns along wall, 2 at steps
    Taylor K-2006
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Do I add cellulose after each backwash!
    Yes it is lost each time you backflush...add enough to raise the pressure back up 1 psi after backflushing. If you are going to be away from the pool for awhile you might want to skip adding the cellulose.
    Jun 2013
    Fortson Georgia
    51
    Re: Do I add cellulose after each backwash?
    I added 4 of the included cups as directed by the instructions on the container. That seemed like ALOT! I had to back wash within 40- 50 min. I did this 3 times & have used almost the whole 1.5 container. Now, should I add 1 cup & wait 10-15 min to see if I get a 1psi increase in pressure before adding more? ( I have 3 more lbs of cellulose)
    Starla
    Taylor K-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by AlphaMare101
    If it's loading up that fast, I'd say keep using it. Try going lighter; it's still a sand filter underneath! Let us know how it works. It seems to me from reports here that the cellulose doesn't raise pressure when adding the way DE does, and I'd like to know. Add a cup and see if it still loads up in under and hour.
    Jun 2013
    Fortson Georgia
    51
    I added 1 cup of cellulose ,no change in filter psi after one hour. I added another cup & no change after an additional 30 min. I think I will check it again in 30 min and leave it for tonight. Or, should I backwash it out before I go to bed?
    Starla
    Taylor K-2006
    Jun 2013
    Fortson Georgia
    51
    1 hour after adding 2nd cup, psi increased by1
    Starla
    Taylor K-2006
