Results 1 to 14 of 14
Thread: Question about salt strips...
    Oct 2012
    North Georgia, USA
    6
    OK...
    the pool looks awesome, if I do say so myself....
    I do still need to lower the TA and raise the CH....
    Planning to lower TA this weekend.
    My iAqualink/Aquapure SWG tells me that there are 3400ppm of salt in the pool water.
    I just used the Check Strips for salt and they said that there are only 2310ppm....
    Which do I believe??
    I added a 40 pound bag of salt yesterday and the iAqualink tells me that the salt concentration went up by 200ppm during the last 24 hours....
    Thanks for advice
    41'x22' freeform, 25,000 gallons. Stonescapes mini-pebble: color AquaBlue. Jandy CV CL580 filter, Jany 1.5 HP Vsp pump, Jandy AquaPure SWG. 5 ton twin waterfall and 17' slide (only running when kids are playing in the pool). Attached Spa with overflow (runs continuously with the Filter Pump). Gas heater for Spa, electric HeatPump for pool. Polaris 9300xi cleaner. Double Main drains, 2 skimmers, Auto-Fill.
    38,524
    Re: Question about salt strips...
    The only thing that matters is what the SWG thinks, so it will keep working. Likely your strips are bad.
    Oct 2012
    North Georgia, USA
    6
    Salt strips are new.
    Just delivered here two days ago along with my nifty, fancy TF-100 chemistry set.
    This is the first time I have used them.
    Hmmmmmmm??.....
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    How new is your sensor in your SWG? Mine was acting funny since last year and as soon as the water warmed up it was all over the place with readings and started throwing errors. My Taylor salt test said 3600 ppm and the SWG said 2700.
    I replaced the sensor and guess what my SWG says now....you guessed it....3600.
    You can also try cleaning the sensor itself per Jandy manual.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    30,432
    Although the range is pretty wide, we have found those Aqua-chek strips to be pretty reliable.
    Would you mind reporting the expiration date? Should be around the latter part of 2014, I think. It's on the top of the yellow cap.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    If you want accurate results, get a Taylor K1766 salt test and double check your results. I calibrated my Jandy to the K1766.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Oct 2012
    North Georgia, USA
    6
    duraleigh: The expiration date on the Salt strips is 12/2014.
    un1017: The sensor is brand new. We just built the pool...filled on May 2-4, 2013....had to use regular chlorine method until Pebble finish was cured. Salt was put in on June 10 and the AquaPure Salt/chlorinator/generator was turned on.
    I'm kinda at a loss....
    30,432
    I would believe the strips. They are part of a very large batch nationwide and a very current. If yours were bad, likely the entire batch would be bad and there would be other reports. Have you calibrated your SWG against any other standard? Maybe stop by a pool store (ugh) and get a "second opinion" if you are concerned.
    Importantly, your SWG is happy and making chlorine.......but I think I'd like it to be a little closer than that.
    May 2013
    Central Texas
    42
    I am having the same issue with my strips, so perhaps there was a bad batch?
    +/-16k gallon IG pebblesheen pool with SWG, spa and waterfall, Hayward 2HP 2-speed Tri-star, Hayward 1.5HP Tri-star, Hayward 5030 Cartridge filter, Hayward H400 Heater, Sharkvac Robotic Cleaner
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    As a side note on this.......I am using the aqua check strips(I think from tftestkits) and I tested my salt with one this morning and got a reading of almost 2500 on salt. I added 100lbs of salt (food grade granulated not iodized) and brushed and tested again in about 2 hours. The strip showed just below the 3180 mark. The pool calculator said 100lbs of salt would raise my salt by 430 if I recall correctly. So basically I'm trusting the strips and questioning the volume I thought of my pool. The expiration on my test strips is also 12/2014.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    I use Aqua Chek strips too. Sometimes the result chart on the labels are different from one bottle to another. Even when new & purchased at the same time. Why?
    Intex Ultra Frame 18'x52"
    Intex 2650 Sand Pump
    Krystal Klear SWG
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Although I do not have a SWG, I use the strips to test salt monthly so I can calculate CSI. Have been using the salt strips for two years (2 separate batches) and have obtained consistent results.
    Jun 2013
    Fallsburg, NY
    258
    Quote Originally Posted by brightblonde
    The result chart on the bottle is calibrated for that batch of strips. Always use the chart from the bottle that you got the strip from.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    There are constant reports of some people using the salt test strips getting wildly wrong results, even though most users get spot on results. You may be one of the unlucky ones who is experiencing test interference.
