Thread: Replacing diverter assembly
    I have a Sta-Rite T-200BP-1 Filter and my spider gasket is built into the diverter assembly. I have heard that these can be a pain to replace. Mine needs replaced because the gasket is smashed in one area. It's either replace it or spend the money to get the whole new muti-port valve since they do not make the one I have any longer. What are your thoughts on pulling the handle apart to replace the diverter assembly?
    Link to my model.
    http://www.horizonparts.com/store/main. ... 6-102-W005
    24000 Gallons
    Cristal-Flo Hi-Rate Sand Filter
    IG - Vinyl
    3/4 HP Pump, and 44 Flow Rate
    Older than 10 years.
    22,553
    Re: Replacing diverter assembly
    They're not too hard to repair. Just take your time and watch what you're doing and it'll go fine.
    Thanks, appreciate the reply. Is there a specific way I should pull the pin off the handle. I received the parts yesterday.
    24000 Gallons
    IG - Vinyl
    22,553
    Not really, though you want to have the diverter assembly compressed while you do it. A vice, clamp, or just manual pressure should be fine.
    What is the proper way to compress it? I have a c-clamp but not sure where to place on top of valve to compress the diverter in order to remove the pin.
    24000 Gallons
    IG - Vinyl
