Thread: Shelf life of Trichlor Tablets
    I am a new pool owner (4 months now) and have recently due to chlorine lock from high CYA switched to BBB method. I am stocking up and researching buying bleach, but am wondering what to do with the 40 or so remaining trichlor tablets I have. I am assuming at some point my CYA, currently 60 after draining, will go down and I could use the tablets, but I don't know how long that will be and if by then the tablets will still be a good source of chlorine...
    Thanks!
    16,250 gal, IG plaster; Jandy Pro Series Equipment: ePump Variable Speed 2.0HP (pool/spa), PlusHP High Head Pump 230/115 VAC .Up-rated 75HP (water feature), Versa Plumb 340 SF filter, & LXI 400KBTU Natural Gas Heater (N) Polymer Headers; Pentair In-line chlorine tablet feeder; Zodiac iAqualink; Clear O3 water purifying system; Polaris 9300 Sport robot, April 2013
    22,539
    Re: Shelf life of Trichlor Tablets
    If you keep them dry and sealed in the tub they came in they will last a very long time.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Aug 2010
    Dallas, TX
    4,052
    You can use them once you get your CYA down to a reasonable level. For example, if you have to go out of town and need something to hold CYA up. I don't recognize your filter, but the occasional use if you have a DE or Sand filter is not too bad, since you'll be washing water out each time you backflush.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Make sure the lid is on tight and I'd guess they'll last years.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yea seal them up and they'll be good for years.
    Jeff
    Mar 2010
    Quakertown, PA
    50
    I switched to bleach about 3 years ago and had about a bucket left. I only used it for vacations and to bring up my CYA each spring (it seems to zero each winter). Just used up my last puck this spring. It'll keep as long as it's kept dry.
    Arvil, 30ft round, 21k gal, AG/vinyl(2003), StaRiteIII hp cartridge 150ft, Polaris65.
    6/30, Temp83F (28.3C), pH 7.8, FC 2.8 ppm, CC 0 ppm, TA 100, CH 80, CYA 40, -B4O7 30, CSI-0.17.
