Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: O ring won't stay seated. Help please!
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    Ok I need some help. I have a carefree waterway sand filter with the multiport valve. A month ago it came unseated. The o ring did not look worn so I placed it back in using some lube. For a few days all was fine and then it came unseated again. So I bought a new o ring and since then the o ring comes unseated every couple of days! I had read about where some require glue? I'm down to this being my only option. Should I superglue it? Is there another problem I might be missing that could cause this? Otherwise it seems to work fine. Any help would be appreciated.
    Robert
    My Pool: 30 ft round above ground, 23k gallons, Hayward CC15093S Xstream Full-Flo 150-Square-Foot 1-1/2-Horsepower Power Flo Matrix Pump
    22,553
    Re: O ring won't stay seated. Help please!
    Welcome to TFP.
    Are you talking about the spider gasket in the valve? If so then you may have to clean it and glue the gasket down.
    You're not turning the valve handle with the pump on are you?
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    It's the ring between the valve and the tank. I make sure I turn the pump off before changing the position of the handle.
    Robert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, CryHavok22
    Looking at pictures of you filter I see that classic design of the flat gasket sandwiched between the valve and the sand vessel and sealed when the large clamp is tightened? Not sure how it doesn't stay "seated"...do you mean it leaks?
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    Yes it starts leaking. Well, it blows water out while the pump is still running. I shut it off and water keeps leaking from around the valve. When I take it apart it seems as though the gasket is not seated properly. So I take it out, clean it, lube it, put it back in to place and everything is fine for a time. Any thoughts on using glue? The lube I'm using I got from the pool store, so I am sure it is the right the one.
    Robert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Looking at the gasket, it looks like it is round in cross section? Does it fit down into a groove?
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    There's no groove with a lip or anything around it but there seems to be a flattened part it goes in to. I have tried putting it there and around the neck part that goes down in to the tank.
    Ty for the help btw.
    Robert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    np...
    Is the gasket "squirting" out from between the two parts?
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    I thought / still think that's what it is doing. I just took it apart again and now I think a little part of tank itself might be worn away. There are two split nut type collars that screw together to make the seal but under that there is a lip around the tank where part of it worn that could be letting the seal break. It's only a year old. Is waterway a cheap brand?
    Robert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Maybe try tightening the clamp until there is just a slight compression of the seal, then see if it leaks and tighten just a 1/4 turn on each bolt (2 right?) until the leak stops, but before the ring "squirts".
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    You think I could be over tightening it?
    Robert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Seems like it is a possibility if the ring is "squirting" out.
    Jun 2012
    Butler, PA
    336
    Tighten both sides together as well ~ don't tighten down one hard and then do the other one. A few turns on the first one, a few turns on the second one and continue alternating between the two until you get them both snug, turn on and see if it leaks. If it does do 1/4 turns and try again. You don't want to "go nuts" tightening until you feel exhausted. Start with a light snug, test and continue on with small adjustments to see if you can find the right pressure point.
    You want them both tightened equally and you don't want "to kill it"
    Edited to add ~ Use Lube too. I would lube the whole o-ring itself and where you are trying to seat it. When lubing the o-ring make sure it feels as it should ~ solid, no chunks missing ~ same size/thickness all around. When you lube where you are seating it make sure that area is clean and dry ~ nothing protruding, lube it & place the O-ring.
    You could also have an o-ring replaced by someone else and they couldn't get an exact match. Fiddle with what you have there though and see if you can get it.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    There are two collars. One goes on and tightens. Then another one threads over the first. I may have over tightened the outer one and damaged the tank. At least that's what I'm thinking now. Also thinking about ending my frustration with a new cartridge filter. Seems wasteful considering the age of this one. Ty for advice guys.
    Robert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Is your o-ring large like this: http://waterwayparts.com/O-RING-MULT...ALVE-805-0435/
    Maybe you have the wrong ring (too small/not thick enough)?
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    That's it. I recognize the part number.
    Robert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I was hoping that was not the ring you had, since I can't see that one stretching enough to "squirt" out.
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    It's humming right along right now. Could last for a few hours or a few days. Very frustrating. Thinking it might be fixed but ultimately having it leak again. Guess it could be a lemon. I'm not sure at this point.
    Robert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Fingers crossed. Personally I would try to figure this one out long before buying another. If it is a problem again, maybe you could post some pics?
  20. Back To Top    #20
    CryHavok22's Avatar
    Jun 2013
    Tulsa Ok
    10
    You're right. I've made it half way through the season this way so I probably won't do anything this year anyway. When it happens again I will snap some pics. Can't thank you enough for trying.
    Robert
