Thread: testing for CYA
    Jul 2013
    Arizona
    4
    testing for CYA
    Hi when testing for CYA if you have fill mixture leftover, can you save and reuse next test or do you need to mix fresh each time? Thanks
    1972, 25900gal, IG, Plaster, DE 36sqft Nautilus FNS,Wisper FlowWFE 3 HP3/4, Pentair Cleaner w/pump Centurion Switchless motor 3/4. Test kit TF-100
    38,251
    Re: testing for CYA
    You need to mix fresh each time.
    Once the reagent is mixed, it is only good for 5-10 minutes.
    22,542
    Re: testing for CYA
    Once you mix the R-0013 with pool water it's only good for that one test. You can pour the mix back and forth between the mixing bottle and the view tube several times but once the test is done, toss the sample.
    Jul 2013
    Arizona
    4
    Re: testing for CYA
    Very good. Thank you so much.
