Thread: Trying to clear up water, what's your opinions?
    Jul 2012
    Georgetown, KY
    31
    I do have water test #'s from the pool store. I go there every couple days(more if needed) and in between those times I use my cheapo test strips everyday. I will have a test kit as soon as I can afford it!
    FC 2
    TC 2.39
    CC 0.39
    PH 7.9
    TA 170
    CH 146
    CYA 34
    There is a couple more readings on various things also. they told me the phosphate level is 1000.
    the water is cloudy blue. just can't seem to get it clear. any help would be greatly appreciated!
    (we use bbb)
    Morada AGP 24 foot, 52 inch deep
    DE filter, 2hp pump, inline chlorinator
    Set up on July 1st, 2012
    Goal is to use the BBB method!
    VERY new to the pool scene!
    Love the Pool School, still learning so much!
    Thank you in advance for your advice and help!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Trying to clear up water, what's your opinions?
    Well if those results are true (often pool store results are not correct), then you are not maintaining a high enough FC level to clear the pool. You need to do the SLAM process. See: http://www.troublefreepool.com/pool-...king_your_pool
    Sep 2009
    Greentown, IN
    914
    Anytime you have cloudy water you have organics in your pool and you need to SLAM your pool. http://www.troublefreepool.com/pool-...king_your_pool
    Phosphates are nothing to worry about when you use BBB. Don't let the pool store talk you into phosphate removal junk... buy a good test kit with the $ instead
    I didn't plug in your numbers in the pool calculator, but your FC should be higher. That's probably the explanation for the cloudy water. Bring your ph down to 75. and then do the SLAM process and then keep your FC at a higher level so you don't risk it going too low again.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
