Thread: what is the depth of the intex pool
    Hi, Looking at getting a 16 x 48 intex. I assume the the "walls' are 48" high. About what level does the water sit at? If my almost 8 year old can stand in it I might go for the 52"
    Thanks!
    38,248
    Re: what is the depth of the intex pool
    Usually the water level is about 5-6" below the wall height I think. Although I think I read that you could keep the water even lower than that.
    EDIT: Actually I am not sure if you are talking about an inflatable ring pool or the metal frame.
    Jun 2013
    Fallsburg, NY
    258
    The max water depth on the 52 is 46", although you can certainly fill it less than that.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    Talking about ultra frame. So I can go lower than 46 on a 52" pool. MMmmm?? Might just go for that. Meijers has 18 X 52 with sand filter for $459. MMmmmm???
    Jun 2013
    Fallsburg, NY
    258
    Yep, you can go as low as just above the intake (which according to the instructions is the lower hole, about half way up the side), I used the lower hole as my output and installed the Hayward skimmer where the upper hole was, which limits how low I can go with water levels, but you won't have that issue.
