Thread: TA says it should turn red mine turned dark pink
    Jul 2013
    Arizona
    4
    Hi im new to your site and have already learned alot from the pool school. I bought a good test kit and have done my first tests. It was easy and fun. One question i have is when the test for TA says it should turn red mine turned dark pink is that the same thing? I didn't want to continue to add drops if i didn't have to. Thanks for the great web site and information i have already saved money on supplies.
    1972, 25900gal, IG, Plaster, DE 36sqft Nautilus FNS,Wisper FlowWFE 3 HP3/4, Pentair Cleaner w/pump Centurion Switchless motor 3/4. Test kit TF-100
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: What we need to know to answer your questions
    Welcome to TFP!
    For any of the drop transitions in color, such as from green to red in the TA test, when you see the color change you add another drop to see if it changes again (mostly in hue). If it does, then add yet another drop. That is, add drops until you don't see a change in color and then don't count the last drop. This technique is so that you don't count an intermediate gray or gray-red as the end when the next drop goes to a more definitive red. Having it be more pink then red may be OK if another drop doesn't change it to a much deeper red.
    As described in the Extended Test Kit Directions
    Continue adding drops until the color changes to something more or less red, pink, yellow, or clear. The sample may switch between green, blue, and gray while you are adding drops. That is not the color change you are waiting for.
    Continue adding drops as long as the color continues changing. The final drop, that does not change the color any further, does not count.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: TA says it should turn red mine turned dark pink
    Welcome!
    Did you get the speed stir? If not your testing will be even easier and more fun with it!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jul 2013
    Arizona
    4
    Awesome! Thanks just what i needed.
    Appreciate it.
    To harleysilo: No i did not get the speed test, but i will thanks.
