Results 1 to 13 of 13
Thread: Compupool CPSC48 cell install
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Heya,
    Anyone know if there is anything wrong with installing the SWG cell directly on 90 degree elbows (see attached picture)?
    It will sure look better this way.
    Just wondering if there is some straight-run pipe requirements before entering the cell.
    Peace.
    35k gallon 20x45 inground concrete with vinyl liner - Stamped Concrete deck
    Pentair WhisperFlo 2HP - Pentair FNS Plus 60 DE
    Heat Siphon heat pump - Compupool cpx48
    Blue Diamond RC robot vacuum - TF100 testkit
    Re: Compupool CPSC48 cell install
    My guess is that they want a straight section before it enters the cell to reduce the turbulence in the cell.
    I've got mine installed with about a foot of straight vertical pipe leading to the cell, and honestly, it is still pretty turbulent.
    Maybe there's another reason I'm not aware of.....
    23,000 IG Plaster pool w/ spa, Pentair FNS Plus 48 DE Filter, Hayward RS1000 Main pump, Polaris booster pump, CPSC48 SWG, Legend pool sweep. Dallas, Texas, Full sun, Taylor K-2006
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Tks rdhetrick.
    I checked with CompuPool and they said right off 90's was ok.
    Showed them the same picture as above.
    Will report back if any issues.
    Aug 2010
    Dallas, TX
    4,052
    Interesting, the cell looks different now. Mine's blue, and has a slightly different shape.
    Looks exactly like mine with the cover off...
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Yeah, the blue cover was off for that picture.
    Aug 2010
    Dallas, TX
    4,052
    I've never taken the cover off!
    May 2012
    Allentown, PA
    219
    I wondered the same thing with my install. I read in the manual that there should be a straight run before the cell. Mine only comes up about 3" above the 90* elbow and I don't notice turbulence. Good luck with the install let us know how you make out.
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Water Fault trouble light comes on for me.
    After working with CompuPool, they are sending a new unit.
    The CPSC series is discontinued recently by CompuPool.
    May 2012
    Allentown, PA
    219
    Since cpsc series is discontinued what are they going to send you. Does your unit produce chlorine even though the water fault indicator is on?
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    They are sending me another CPSC48, they are continuing to support the warranty on them, but no longer selling them as new once the stock out there is sold off.
    It is still generating chlorine even though the water fault light is on.
    Estimated 2 week backorder on the replacement.
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    August 2nd and still no replacement sent from CompuPool.
    They said another week before they anticipate the backorder for my parts to fill.
    Waaaaaaaaaaaayyy too long for replacements parts for a unit that showed up broken.
    ....and the place I bought it told me they have none as they are discontinued.
    Yikes!
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Same run around from CompuPool. They claim parts still on back order.
    Every week they say, "next week for sure".
    Welp, swimming season is almost over here in the NorthEast.
    Argh..
