Results 1 to 13 of 13
Thread: Calcium scaling and high LSI. How should I fix this?
    My pool has developed a rough, sandpaper-like texture on the plaster surfaces that used to be smooth. Correct me if I'm wrong, but I assume this is scaling. I also have white staining on the tile at the waterline.
    It's a non-saltwater plaster pool using Chlorine. The pool is a couple of years old and the pH tends to creep upward if I don't stay on top of it. I assume that it got high and stayed high over the winter while the pool was closed.
    My CH seems rather high, probably because I've been using cal-hypo.
    My current levels are:
    Temp: high 80's to low 90's. Currently 92.
    FC: 7-10 (try to keep it around 10.)
    pH: 7.6 (I try to keep it right at 7.6 with daily testing, and have been for the past 2 months since we opened)
    TA: 90
    CH: 350
    CYA: 70
    If my calculations are correct, this gives me an LSI of 0.41, which can cause scale.
    So, two questions:
    1. What's the best way of going about changing the levels above to get the LSI to a balanced level that won't cause scale?
    2. What's the best way to remove the scale that has already formed on the plaster?
    15'X48" cheapo Intex metal frame pool. 4400 gallons.
    Cartridge filter
    The only thing I could find about the pump is it says 1000 gallon filter pump.
    22,544
    Re: Calcium scaling and high LSI. How should I fix this?
    The easiest and best thing to do is lower the pH to about 7.2 and do your best to keep it under 7.5 all the time.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Bama beat me, but here is my take...use poolcalculator.com to calculate your CSI (calcite saturation index). According to the poolcalculator.com your csi is ~0.09 which is right in the middle (and should not cause scale), but that doesn't mean your CSI has always been good. See this pool school article: http://www.troublefreepool.com/pool-...alcium_scaling
    By the way, your CH level is not too bad...but I would stop using the cal-hypo and switch to bleach/liquid chlorine to chlorinate.
    38,271
    Not related to your question, which Dave covered, but:
    Is there a reason you are keeping your FC so high? Minimum is 5ppm for your CYA of 70ppm. For that matter, is there a reason you have your CYA so high for a non-SWG pool?
    Will this eventually remove the existing scale, or just prevent more from forming? Is it safe to swim in with a pH of 7.2?
    For some reason I had it in my head that the CYA chart said 10 FC at 70 CYA. Looking again I see that it should actually be at 8 FC. I'll correct this. Thanks!
    I have the CYA so high because the pool is in full sun all day and we live in a very hot, sunny area. The FC level drops extremely fast. I assumed that a higher CYA level was the best way to slow down the breakdown of the Chlorine. Please tell me if I'm wrong and should lower the CYA!
    Quote Originally Posted by linen
    According to the poolcalculator.com your csi is ~0.09 which is right in the middle (and should not cause scale), but that doesn't mean your CSI has always been good. See this pool school article: http://www.troublefreepool.com/pool-...metal%20stains
    My CSI is "balanced" but my LSI is "scale". Which one should I believe?
    I looked at the Metal Stains article you linked but it seems to be discussing Iron and Copper stains, not scaling. Am I missing something?
    Thanks, everyone!
    Cartridge filter
    22,544
    If you keep the pH at 7.2 it will eventually remove the scale that has formed. It is a slow process but it will happen.
    It's perfectly safe to swim at 7.2 pH.
    38,271
    Yes, pH of 7.2 is perfectly safe and if you maintain a negative CSI (we do not look at LSI) and brush a lot, the scale should diminish ... but we are talking about years timeframe, not days here. If you want is removed immediately, you would have to do an acid wash.
    You are right that the higher CYA should protect the FC better from the sun. The only issue with higher CYA levels is that the shock level required for the SLAM process gets to be pretty high if you develop a problem.
    I think linen meant this article (just above the metal one in Pool School): pool-school/calcium_scaling
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yep I did ...fixed now.
    Thanks, everyone. I'll maintain pH at 7.2, brush often, and hope for the best.
    What's the lowest pH at which it's safe to swim? (In case I mess up occasionally).
    Cartridge filter
    38,271
    Keep the pH above 7 so it is measurable ... although should be "safe" even below that some.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by Ack
    You need to adjust the TA for the CYA level. The CSI and LSI calculations uses the adjusted TA. The Pool Calculator does this automatically for you. If you are using the Taylor watergram or something similar, they expect you to adjust the TA based on your CYA level. At your CYA and pH, you would lower the TA by 24 ppm -- the rough rule-of-thumb is to subtract 1/3rd of the CYA level from the TA to get carbonate alkalinity used in the LSI calculation.
    Even if your CSI or LSI were a little high, you usually don't get scale from that so something doesn't sound right about this situation.
    Quote Originally Posted by chem geek
    The pH in my pool tends to naturally creep up pretty quickly. I suspect that the pH level got pretty high over the winter while the pool was closed and then sat that way for months. I can't be sure though because the pool company that opens the pool for me dumped in some acid before I could measure anything.
    Cartridge filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Oh, in that case, then it's possible, if the pH went quite high.
