Thread: I need help to fix my pool light!
    I need some help on what size of light gaskets for my 30 year old pool lights that still work. I realize that these lights are most likely not made anymore; however I don't want to buy new lights if these just need cleaning. The glass lens are dirty inside and I want to clean them and replace the gaskets. I will shut off electrical power to the pool for this project. The larger one has a glass lens about 7 inches in diameter which is surrounded by a metal face plate that was made by Purex. The smaller light is about 3.5 inches in diameter surrounded by a metal face plate that doesn't have a name on it; see photos. Also please recommend where to buy online for fast delivery. Thank you!
    11K gal, AG 15x26x54, 18" Hayward sand filter 1 1/2hp
    May 2011
    Orange County, CA
    696
    Re: I need help to fix my pool light!
    Can you make out the labels on the light housing for either? You may be able to search on the web and find some gaskets. Purex parts are still available from several online vendors.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Aug 2010
    Dallas, TX
    4,052
    Mine isn't made anymore either!
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I know nothing about pool lights, but auto parts stores often have gasket material to make your own gasket. Just a thought.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Thanks for your replies. I opened up the light and it was filled with a dark gooey substance that was too difficult to clean, so the pool light was irreparable. Thanks for your ideas. I am going to have to replace the entire lightxprobably with a Pentair.
