Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 91
Thread: Just filled - Results added. Please help balance.
    Jun 2010
    Toronto, ON. Canada
    230
    We have a brand new pool and the liner was installed on Tuesday.
    10 bags of salt were added.
    I took the water to test at PB's store.
    Here are the results:
    Salt: 3200
    FC: 1
    TCL: 1
    PH: 7.6
    APH: 7.6
    TA: 120
    ATA: 120
    CYA: 0
    CA: 140
    I had agreed with the PB that he would balance the water the first time.
    They have asked that I put in:
    9.5kg of Calcium Plus
    19Kg of salt
    6.7kg of Salt One
    Here is what I have on hand from the Pool Store that they have given me (free).
    8Kg of Calcium Plus
    5kg of Salt One
    A package of KlearSok (125g)
    3 x 450g packages of shock plus
    1 L of Sparkel (concentrated clarifier)
    I put my results in pool calculator and it says to:
    72oz of 6% bleach
    7.8oz of muriatic acid
    307 oz of calcium chloride
    Add 115oz of stabilizer
    Add 43lb of salt
    What do I do now. I have some stuff from the PB.
    What exactly should I add now to get all balanced?
    Want to get the pool ready for the weekend.
    Thanks!!
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    38,251
    Re: Just filled - Results added. Please help balance.
    No point in adding calcium.
    Just get some stabilizer in the pool and maintain adequate FC levels with bleach. Get the salt adjusted and after 24 hours you can start dialing in the SWG output.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Shaf77
    Salt: 3200
    FC: 1
    TCL: 1
    PH: 7.6
    APH: 7.6
    TA: 120
    ATA: 120
    CYA: 0
    CA: 140
    19Kg of salt
    6.7kg of Salt One
    8Kg of Calcium Plus
    5kg of Salt One
    72oz of 6% bleach
    Add 43lb of salt
    Thanks!!
    Hmmmm... You don't really need CH in a vinyl-lined pool, but it does reduce foaming. And assuming there's some caveat in the contract that says you need the water tested by the PB at certain intervals, I'd add what Calcium Increaser you have on hand - not that it needs it, but to cover yourself.
    Salt One - never heard of it. Sounds like a gimmicky mineral sanitizer. See if you can't find the ingredients and post it here.
    Klear Sok and Sparkle are both clarifiers that hopefully you will never need.
    The Shock Plus might be useful, if it's dichlor or trichlor. They'll add CYA as well as FC. If you can read the labels or post the ingredients or the exact manufacturer name and maybe even part number so we can figure it out, we'll let you know if it's useful.
    But you definitely need to get some CYA in there, quick, and a little more chlorine. I doubt the SWG will be able to keep up with no CYA.
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks for the quick and awesome responses!!
    No contract with PB to maintain CH.
    jblizzle - What should I use for stabilizer? I need to get the CYA up.
    All the stuff I have from PB is from IPG (http://ipgcanada.com/en/index.php/types ... -chemicals)
    Will not use the klearsok and Sparkle for now.
    Still confused.. what do I add just now to get CYA up?
    Jun 2010
    Toronto, ON. Canada
    230
    Just checked my laundry room and i have some bleach. Its Clorox Ultra - http://www.cloroxprofessional.ca/produc ... ng-bleach/
    The MDPS online (http://www.cloroxprofessional.ca/pdf/Ul ... Bleach.pdf) says it's 5-8% sodium hypoclorite?
    38,251
    Like Richard said, what are the ingredients of the "Shock Plus"?
    Otherwise you need to go buy some stabilizer = conditioner = CYA = cyanuric acid.
    I think that is just plain bleach, so that will help with the FC level.
    Jun 2010
    Toronto, ON. Canada
    230
    Shock plus is from IPG. Says Chlorinating granules on package. Controls bacteria and Algae. Calcium Hypochlorite 65%Available chlorine content 65%
    38,251
    So that is cal-hypo and will not add CYA, it will add more CH instead in addition to the FC.
    38,251
    And to head off you next question ... you are going to need at least 10 pounds of granular stabilizer to get up to the recommended levels for your SWG. Although you likely do not want to add all of that at the same time.
    Richard320's Avatar
    Jan 2010
    18,967
    Still confused.. what do I just now to get CYA up?
    In that case, skip the CH increaser.
    And ipg is playing secret agent on their chemicals, so toss that shock plus unless it says what it is on the bag. "Shock" means nothing; it's about as descriptive as saying "candy." What kind of candy? Is it soft, is it hard, is it chocolate...who knows? Rule of thumb: never add anything to the pool unless you know what it is.
    Stabilizer is a descriptive term for Cyanuric acid aka CYA. You can buy it at big box stores and hardware stores probably for less than the pool store. The liquid mixes in minutes, the granular takes a few days to dissolve. Do NOT follow their directions. Instead, pour it in a sock or nylon, tie it up, and suspend it in front of a return with some string, or tie it to a floating toy and let it bob around in the pool.
    That bleach you have is fine. Treat it as 6% for calculations.
    Jun 2010
    Toronto, ON. Canada
    230
    Oh boy. Now.. where do I buy that from? (First time pool owner)...
    38,251
    Around here I would say Walmart or even the big hardware stores, but not sure what you have up there. A pool store would certainly have it, although you should be able to find it cheaper somewhere else.
    Richard320's Avatar
    Jan 2010
    18,967
    Plug in your postcode
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by Richard320
    Amazing! Thanks!!
    So I need about 5 of those. Its $13 each at a Walmart about 10mins away.
    When you posted HTH, I realized that I had a few things I had bought from Costco months ago.
    I have these items in the garage. Please let me know if I need any of them. If not, I will return to Costco over the weekend.
    1. HTH Test and Balance Kit
    2. HTH Shock treatment box
    3. HTH Algae stop 15
    Had forgotten about these until I saw that pic of hth you posted.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would return those to the store. Using the BBB method we normally ad chemicals with one active ingredient so we know how it will effect you pool. We will not need an algaecide until the end of the season but you could keep it for when you close the pool for winter. The test kit does not contain the critical FAS-DPD chlorine test.
    -- Guy --
    Jun 2010
    Toronto, ON. Canada
    230
    This might be a stupid question.. Since the PB suggested adding 9.5kg of Calcium Plus, 19kg of slat and and 6.7 kg of salt one.. What If I just used that since I have it on hand and then later when I test again, go through BBB?
    38,251
    Because none of that adds the CYA you need.
    Jun 2010
    Toronto, ON. Canada
    230
    Why would the fools at the pool store ask us to add those??
    38,251
    Because they clearly do not understand pool chemistry and think you need to rasie the calium level in your vinyl pool and think that your salt is a little low, although it seems in range to me.
    Admittedly I have no idea what is in Salt One.
  20. Back To Top    #20
    Jun 2013
    SpringHill FL
    415
    They are in buisness to sell products not all of them are bad but most only know what the chemical companys tell them
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
