Thread: Prepping for hard plumbing
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I am right now at the stage of gathering parts for my hard plumb project, and need a little info.
    I'm planning on having a through wall skimmer, and would like to have an additional suction fitting with valve for vacuuming. Would this be the same fitting used for the returns, or is there a special one needed for this?
    Feb 2013
    Yukon, Oklahoma
    220
    Re: Prepping for hard plumbing
    I would just make sure however you are planning on vacuuming that the plumbing that you will have in that old Intex intake position will fit the equipment you plan to use. Of course a nice PVC valve to control it all is mandatory too.
    Bob E.
