Thread: Lowering CYA
    Lowering CYA
    First, I want to say I am so thankful I found this board! I love learning how to be in control of my pool!!
    My CYA is high, about 110. I bit the bullet and am doing a partial drain today. My handy husband (who by the way is clueless about the chemical balance since that is my job) hooked up some PVC so I am using the drained water to soak my lawn hopefully the chlorine doesn't hurt my lawn.
    I have switched away for TriChlor to liquid. I still have lots of tabs left. How much CYA is released per tab? If I let them sit around and use them slowly over the next 6-12 months won't they lose their potency? I'm wondering if I can leave 1 puck in the floatie just in case the chlorine level drops?
    Thanks!
    New pool owner 3/2013 14,000 gal pebble tec, 7 ft jacuzzi with spillover into pool.
    FNS +48 DE filter, raypak2100 heater, Pentair whisper flo 1.5, Hayward pool cleaner. TF 100 test kit.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Lowering CYA
    Congrats on your new found knowledge and becoming a BBB 'er. You can use the pool calc, effects of adding chemicals. to answer you questions.
    Jeff
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Lowering CYA
    Keep them dry and they'll last forever. As for CYA per puck, scroll all the way to the bottom of the pool calculator. Each puck will be either 7 or 8 oz.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Lowering CYA
    If they are 3 in tabs (about 8 oz) then they each one will add about 1.8 ppm cya to your 18000 gallon pool. I used the "effects of adding chemicals" section near the bottom of the poolcalculator.com. They also lower ph and TA.
    If you keep them dry, they should last a long time.
    I see no reason to keep one in a floatie if you are testing and dosing daily with bleach/liquid chlorine. Save the pucks for vacations (and make sure you watch your cya when you use them).
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Lowering CYA
    You can use the pool calculator to see how much tabs "put out". Usually about 60% of the chlorine amount they do. Keep them in the plastic bag inside the screw lid plastic container and they'll keep a loooooong time. One puck in a floater won't kill ya' if you just have to until you wean yourself!
    Re: Lowering CYA
    Thanks everyone. I didn't realize the pool calculator would show me the calculation.
