Thread: intex 1600 sand filter pump
    just bought 20 x 52 ultra frame pool with pump.im not using the new pool yet im just using the pump on my 18 x 48 intex.i have pump hooked up but it seem to barely be pumping theres also not much suction going into pump.is there something i did wrong maybe?
    Doughboy 24ft Round Above Ground
    13,000 Gallons
    Sequel 1 DE filter
    Intex Salt water generator
    Just filled on 06/28 YIKES!
    Michigan
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: intex 1600 sand filter pump
    Welcome to tfp, wrightchris3
    When you first hooked it up how was the flow?
    Have you backwashed it?
    What did you use for sand? Did you do a long backwash after adding the sand?
    I have the silica sand. I didn't back wash it very long at all.IM new to pools. and the flows is the exact same from when I started it
    13,000 Gallons
    Sequel 1 DE filter
    Michigan
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The silica sand...was it labeled as pool sand?
    Do you have air in the pump basket cover? That would indicate a leak on the suction side of the plumbing (plumbing from pool to pump) and can reduce flow rate?
    Maybe post a picture of your setup.
