Results 1 to 9 of 9
Thread: installing elbow on new hayward super pump
    Hi Guys,
    I had to buy a new pump; and bought the exact same one; hayward super pump.
    I have the same setup as the picture.
    The problem I have now is I took the elbow from the old pump and put it on the new one; the problem is when I tighten it ; the elbow doesn't line up like the previous one did.
    I bought another elbow from pool store; it didn't line up as well.
    If i get it lined up since its not tight; i get a slow leak at the bottom of the pump.
    Any suggestions I can try?
    Arthur
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: installing elbow on new hayward super pump
    Is the elbow a Hayward branded elbow or generic? Hayward uses some proprietary thread nonsense on their equipment.
    kyser's Avatar
    Jun 2013
    Orange City, FL
    47
    Can you place shims between the pump mount and the base plate?
    I've seen inexpensive plastic cutting boards used as spacer material and mounting plates for chem pumps. They are pretty easy to work into customized shapes with hand tools.
    6.7K Pro Series 18x48, VL40T32 pump/filter, Hayward skimmer, TF100, and BBB!
    Hi,
    I took the elbow from old pump which was the same hayward model.
    I also bought another one from pool store; it was a hayward part;
    They both don't align up correctly .
    My friend said put a bunch of Teflon tape
    So it will stop where you want it to.
    I didn't think it would be this hard.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If the old pump overheated then it may have distorted the pipe fitting, usually makes them taper more than they should. If pipe fitting is good I suspect teflon tape is your best bet. Note that is a Hayward custom elbow and the middle of that union has a sort of ball and socket joint to allow some flex.
    Ike
    Smykowski's Avatar
    Sep 2011
    3,065
    Slather it up with pipe dope?
    Jun 2013
    SpringHill FL
    415
    Wrap teflon around the threads thickly i had to do the same on mine
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Thanks for the help, I wrapped it up with Teflon tape, than slater it
    In pipe dope stuff. When I put it on, I didn't tighten it all the way; just to where it would
    Align to the filter.
    I also waited an hour before installing in back to pool.
    So far no leaks!
    Thx much
    Jun 2013
    SpringHill FL
    415
    Good to hear bud now relax and enjoy a troublefreepool
    Nathan
