Thread: Using polaris with filter line shut
    My polaris has only been running about 21 rpm so I have been trying to boost it. Anyway when I shut the value to run through the filter it gets me up to 30-32. Is this bad on the motor/components? Everything I have been searching talks about not running the booster pump without the main pump - however my system only have 1 motor to run everything.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Using polaris with filter line shut
    Welcome to TFP!
    Which Polaris model do you have?
    Thanks!
    I am not at home to verify but judging by the pictures online I would to say a 360 ( I have only lived in the house for 6 months but would guess the cleaner is at least 5+ years old.
