Results 1 to 8 of 8
Thread: Another newb needs help, sorry lol
    10k gallon concrete pool, just got a Taylor test kit, and oh yeah, my pool is a disaster! I was using strips and tablets and thought I was king. Then my pool turned green and here I am. Any and all help is greatly appreciated, thank you!
    Today's numbers:
    FC 0 ppm
    CC .6 ppm
    pH >8 (scale only goes up to 8)
    TA 100
    CH 320
    CYA 115
    Please help me fix this
    Matt
    1ok gallon concrete, it looks like a pair of sunglasses if viewed from above. 2 skimmers, 1 drain in the deep end, 2 regular jets and 1 smaller jet that looks like a PVC elbow. Hayward C900 Cartridge filter. 3' low end, 6' deep end.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Another newb needs help, sorry lol
    Welcome to TFP.
    It is time for the SLAM PROCESS. Instructions are in pool school.
    The high CYA level is going to use a boatload of chlorine.
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Welcome "king"! An out of control pool will make a peasant out of anyone in short order
    Reduce your ph to low 7 range pronto. Consider replacing some water ( in steps) to lower the CYA to a manageable level. Consider ordering one of the test kits in pool school. Read pool school a couple times and SLAM the pool with plain old bleach.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    How high is your water table? If it is normally lower than the bottom of your pool, the first thing you should do is drain and refill 1/3 of your water, then test the CYA again. Target should be between 30 and 50.
    Next would be to bring your pH down with Muriatic acid, to around 7.2.
    SLAM your pool as soon as you get your CYA and pH under control.
    You are probably going to need large amounts of bleach. The drain and refill will reduce the target SLAM considerably.
    http://www.poolcalculator.com will help with dosage.
    Pool School will help with the how and why of these steps.
    Jun 2012
    Howell, NJ
    977
    How did you get a CYA level of 115? The CYA test will report anything over 100 as about 100, so you may want to use dilution for the CYA test. Mix 50% pool water and 50% tap water and double the result to get a better estimate of your CYA.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    thank you guys for the info. Yes, my range for the cya stops at 100, I was well past that mark so I figured it was around 115. I am in south fla so my water table is about 3' I used the calculator yesterday and put in 240oz bleach and 75oz acid.
    yesterday today
    FC 0 14
    CC .6 .5
    pH >8 7.0
    TA 100 70
    CH 320 320
    CYA >100 95
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Things look alittle better. CYA still high. Are you SLAMING ?
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,024
    [quote="SSDIPainGuy"]thank you guys for the info. Yes, my range for the cya stops at 100, I was well past that mark so I figured it was around 115. I am in south fla so my water table is about 3' I used the calculator yesterday and put in 240oz bleach and 75oz acid.
    Find a graduated cylinder or a measuring cup - anything that will be accurate - and mix pool water and tap water 50-50. Mix it good. Then use that as the sample water and mix it with the CYA test reagent. Take a reading, pour it back in the mixing bottle, shake it again, and take another reading. Do it as many times as you need until you start getting similar readings consistently. Then double that. That's your CYA level.
    Knowing tap water has zero CYA, it's simple arithmetic to figure out how much water you should drain and refill to get the CYA number down to a reasonable level. It's probably cheaper than you think, and will likely pay for itself in reduced chlorine purchases to perform the SLAM process.
