Thread: High CYA
    wjr75's Avatar
    Jun 2013
    IL
    836
    High CYA
    Hi Guys,
    I have learned a lot from you guys after opening my pool this year. Unfortuantley I'm not home all the time and need to use my auto chlorinator with some Lesie's pool 3" pucks. When I opened my pool they had me put in 6lbs of stabilizer after a fresh fill. I also had some cloudiness a few weeks ago and used a few bags of the powdered shock they sell and boosted also with it. Now my CYA is 90 arggh!!! (use the FT-100 FOR TESTING). I live in the Chicago area, can I just keep my FC in the 8ppm range using bleach for the next 2 1/2 months before closing my pool? Would this still be good if my CYA might go up to 120? I want to avoid having to drain if I don't have too. Thanks in advance.
    fc=8
    ta=170
    ch=260
    cya=90
    ph=7.3
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: High CYA
    You can if your going to be very diligent about maintaining that level of FC. otherwise replace some water.
    Jeff
    30,432
    Re: High CYA
    What you are asking is if you can successfully operate your pool at the very outer limits of what we suggest for guidelines. The answer is, "Yes", but the caveat is, "If you're lucky"
    Pools become almost unmanageable when the CYA is as high as yours and it sounds like you want to drive it higher. When it becomes cloudy again (and it almost surely will) the powder you put in there will only make the situation worse and if you get an algae bloom, you may need a tractor-trailer to bring enough chlorine to fix it. (SLAM value for a pool with 100 CYA is 40 ppm of chlorine)
    So, the real answer is don't do that. Bite the bullet and drain some of the pool and get it back to where you can take care of it with reasonable amounts of chlorine.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: High CYA
    Duraleigh was very diplomatic in his answer.
    Here's mine: CYA of 90 is managable if you switch to liquid chlorine immediately, stop using pucks or powder, and test and dose every day so that you never come close to your min FC level. If any one of those things is too difficult, then no, CYA of 90 is too high.
    Jun 2013
    Fortson Georgia
    51
    Re: High CYA
    I just went through the same thing. I started with a green swamp 5 weeks ago & used a TON of dichlor most of which was added within a 2week time frame-110 lbs l!(pool store advice). Pool store kept telling me my water tests were" fine". My pool went from green to blue, but would not clear. I struggled with no improvement after adding clarifier, flock, etc $$$(More pool store advice).Pool store said CYA was 100 & stated "that level is just fine") Then I discovered TFP & ordered my test kit. My CYA had got up to 180!! Bite the bullet & drain some water. Water is cheaper than all those chemicals. I drained down to 18 in. in shallow end & would have drained more water but I was afraid my liner would float. I am shocking with CYA of 80(SWG) & I have already used 16 gallons of 12% liquid chlorine in 3 days. I'm not through yet!! I would have been $$ ahead & had a clear, beautiful pool weeks ago if I'd have drained it in the beginning. The advice on here is AWSOME!!
    Starla
    1993 22x42(40K gal) vinyl Grecian, inground
    Aquarite SWG, Hayward s244t sand filter & 1hp Hayward pump, polaris 380 w/booster pump and dedicated return.
    2 skimmer baskets, main drain, 3 returns along wall, 2 at steps
    Taylor K-2006
