Thread: How quickly with this pump/filter cycle water
    I am using the pump/filter that I got with this AG pool ... I am trying to figure out how much run time I am going to have. Should I consider an upgrade next year?
    Here is the information on the filter and the pump ... I guess I need to figure out how quickly the water will cycle with this set up ... how often I need to run the pump ... and if it is sufficient ...
    (and what of this information I need to put in my signature!)
    Filter - Hayward sand filter
    1.4 sq ft filtration area
    25 GPM dssign flow rate
    35 GPM filter and backwash rate
    50 PSI max work pressure
    Pump -
    Sta-Rite
    3/4 HP
    3450 RPM
    SwimNPlay AG 15x33 oval 48" high 12k gallons - Used pool set up July 2013
    Hayward sand filter, Sta-Rite 3/4 HP pump
    Kleen Machine Robot, TF-100 test kit
    Central NC
    38,301
    Re: How quickly with this pump/filter cycle water
    Flow rate does not matter. Run it as long needed to keep the pool looking clean. See the article in the How To section of Pool School.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Right now I run mine in two 3 hour shifts. One during the day and one at night.
    What ever keeps your water looking good.
    Jeff
