Results 1 to 8 of 8
Thread: Can I use??
    Jun 2013
    Miami,Fl
    9
    Can I use??
    Can I use Borax as a stabilizer?
    Pool Size: 16'x32' 14,200 Gallons with spa
    Pool Type: Inground,Diamond Brite Blue Quartz
    Pump:STA-RITE 2hp Pump & AquaPure PLC700 SWG (New Version)
    Filter: STA-RITE PXC 150 Cartridge
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Can I use??
    As in CYA ? No.
    Jeff
    lee872's Avatar
    Central Massachusetts
    59
    Re: Can I use??
    Don't think that'll work for you. Pool Calculator shows Borax raises pH, TA, and borates. Are you trying to raise CYA?
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    Re: Can I use??
    Borax can be used to increase pH. It can also be used to add borates, which stabilize pH. However, if you mean to stabilize chlorine, then no, it won't do that.
    Support the site
    38,345
    Re: Can I use??
    As a stabilizer for what?
    Jun 2013
    Miami,Fl
    9
    Re: Can I use??
    Yes I am.
    FC 1 TC 2
    PH =7.6
    TA =100
    TH = 250
    CYA /stabilizer= 50-60
    I live in Miami & my pool is in direct sunlight all day.
    I lose TC daily..but I do have to replace my SWG b/c its bad.
    I should replace it on Sunday so I'll see then. Can only use CYA for stabilizer.
    And my pool very clear ..looking beautiful using the BBB method..
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Can I use??
    You will lose FC daily regardless. If your FC is at 1 now you better get some in there ASAP.
    Jeff
    Jun 2012
    Howell, NJ
    977
    Re: Can I use??
    CYA is the only thing you can use to protect chlorine. That FC is too low for a CYA of 50, it should never drop below 4. Also, according to your results, your CC is 1, which means there may be something growing in your pool. You may want to do the OCLT, which is in pool school, and if you fail, you will need to follow SLAM, which is in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
