Thread: 2" to 1.5" pipe question
    Hi all, I have a question, currently i replaced my pump to pentair whisperflo pump, but the pump is 2" pipe and my current pipe is 1.5". The PB installed to me and they put the 2" to 1.5 pipe connect to my current pipe and the pump. Did this cause any problem?
    - NY Albany ~27000 water
    - In ground Vinyl 18' X 40' X 8' Deep Curved Roman End
    - Pentiar TA 60 Sand Filter
    - Pentair WhisperFlo 1HP Energy Efficient Full-Rated 2-Speed
    - 250K BTU Nat/Elec. Heater
    38,521
    Re: 2" to 1.5" pipe question
    What other option would there be? (assuming I understand your 2nd sentence that is not very clear)
    You would have to use reducers somewhere to interface between the different diameters. There are some better places to do it depending on your setup up, but it should not hurt anything.
    Yes, i mean 2 to 1 1/2 reducer to connect the pump and current pipe line.
    That should be fine. Pumps are happier if they have one foot of straight pipe before the pump that is 2", but even that isn't required 95% of the time.
