Results 1 to 16 of 16
Thread: Test Kit Came Today! 1st results - NOW WHAT?!
    Jul 2013
    Grenada, MS
    7
    My test kit (TF-100) FINALLY came in the mail today, and I have my first test results (below).
    But now I'm not sure what to do next....????? Any advice would be greatly appreciated! Thanks in advance!
    FC = 11.5
    CC = 0
    pH = 7.2
    TA = 140
    CH = 50
    CYA = 35ish (this one is really hard to read!)
    I'm new to pool chemistry. My pool has only been up for about a week and I have NO IDEA WHAT I'M DOING!!!!
    Intex 22' x 52" Ultra Frame (round). Above Ground. Intex 2,500 GPH Pump with Cartridge (B) Filter. (hoping to upgrade to sand filter as soon as possible!)
    ***IT'S HOT IN MISSISSIPPI!!!***
    30,421
    Re: Test Kit Came Today! 1st results - NOW WHAT?!
    Welcome to the forum. What does your water look like?
    38,301
    Welcome to TFP!!!
    Hmmm ... well ... I would suggest since all the numbers look good, assuming the water is clear
    Sure the FC is a little high, but that will come down. Just make sure you keep it above 3ppm at all times based on your CYA level.
    I assume you have read through Pool School a few times?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    I think the Op is pulling our leg. That's almost picture perfect numbers "right outta the box." Great job. I'm from Clarksdale btw.
    Butterfly's Avatar
    South Carolina
    10,045
    Nice work As they mentioned, let the FC drop down to maintenance level and keep FC between 3 and 6 and never below 3.
    You're done SLAMing when:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can see you've done your homework.
    Good job and welcome to TFP !!!
    Jeff
    Jul 2013
    Grenada, MS
    7
    Duraleigh, my water looks clear.
    I was a little worried about the FC numbers because it is SO high! I didn't know if it was safe.
    Yes. I have read pool school a few times but I need to read it a few more. I've been doing the best I could with the aquachem test strips from Walmart. I used those to "guess" my levels and then I put my estimates into the pool calculator as best I could and went from there.
    I put in bleach, baking soda, and borax. I also shocked it a few times and have been using a floater with pucks to try and get some CYA into the water. The CYA test is REALLY hard to read. I hope it gets easier with practice. Best I could tell, mine was between 30 and 40. Is that high enough? Do I need to keep using the pucks for a while until it goes up a little? I know when it reaches 40 or 50 that I need to stop using them.
    Should I be concerned about the low CH (50)? I read that its not as important in a vinyl pool. I just want to make sure because that seems really low!
    Do I need to trying and bring my pH (7.2) up? Is there a way to do that without also bringing up the TA? My TA is already 140 and that seems high to me. Should I be worried about that?
    I'm sorry about all the questions. I'm just a ball of nerves!!! I want all the numbers to be perfect!!! I'm a little OCD I. You haven't noticed!!!
    Thanks guys! I really appreciate all the quick responses I got. Y'all are already amazing!!!!
    Apr 2010
    East Texas
    9,609
    Ph at 7.2 is bottom line minimum but ok. You can aerate to raise it without effecting TA. Your CH is fine--mine has been that for 4 years. Fc will drop soon enough in the heat!---but you're good to swim Perfection is overrated------ranges are a lot easier to live with!
    Jun 2012
    Howell, NJ
    977
    A CYA of 35 is fine, unless you think you are losing a lot of FC to the sun every day. I think typical loss is usually around 2-4 ppm per day. I would stop using the pucks now, because they are acidic and are driving your pH down. If you don't have a horribly acidic water source, like me, your pH will tend to drift up over time. CH of 50 is fine for a vinyl pool. If it makes you feel better, mine is about 20 right now. I think I answered all of your questions, correct?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jul 2013
    Grenada, MS
    7
    Ok. I will stop using the pucks and I will stop panicking about the CH. I will keep my eye on the pH and hope it comes up a little on its on since I don't have a way to aerate it. My only question left is the TA. Is that too high? Should I try and bring it down any?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would leave TA alone.
    Jeff
    Jul 2013
    Grenada, MS
    7
    Quote Originally Posted by pwrstrk
    Sent from my iPhone using Tapatalk.
    Ok thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Go swimming
    Smykowski's Avatar
    Sep 2011
    3,065
    Kinda strange that we didn't answer you with a laundry list of expensive chemicals to buy, huh? After all, that's what the pool store would do....
    Jul 2013
    Grenada, MS
    7
    Quote Originally Posted by Smykowski
    You know, I was kinda thinking the same thing! I was expecting to have to go to the store immediately and buy kinds of stuff! I thought my numbers were WAY off! Now my husband wants to know why we spent so much money on a test kit and we don't even have to add anything to the pool!!! I told him to just be patient because EVENTUALLY we would have to add stuff!
    Thanks guys!
    38,301
    You need the kit so that you KNOW you do not need to spend money to add anything.right now.
